As said before i made 225rwkw at 16psi boost. It was my first time at the runs and only like the third or fourth night id taken my car out since modifying it, so im still not used to the launch.
Anyway 3 out of the 4 runs I had I got in the 13.1 bracket. My final run i was spewing my third wouldnt go in and i was driving the best!!!!!!
Best Time:=
60' 2.175
330' 5.741
660' 8.605
mph 86.82
1000' 11.077
ET 13.142
MPH 106.44
KM/h 171.3
Final Run (Missing third)"=
60' 1.948
330' 5.478
660' 8.632
mph 81.06
1000' 11.206
ET 13.342
MPH 103.02
KM/h 165.79
Im pleased with the results but what time do you reckon i could of got if I didint miss third according to my 60ft etc?
https://www.sau.com.au/forums/topic/65587-my-results-first-time-at-runs/
if you hadn't missed third and managed the same trap speed as the other 13.1 run, with the 1.9 60" time.. you might have got a 13.00 or possibly just in to a 12.99 area.
what wheels/tyres?
how much tyre pressure did you have?
what suspension?
16psi boost? what turbo?
nice work for your first outing..
will get much better as you get used to it
Hey dude, i was next to you in the 13.1 run. Not fair you got more boost than me :(
What car where you in what time did u get?
Ive got 17inch mag wheels on my car and i put the back to 20psi and front i left basically normal. My cars got cut springs, i wana buy sum pineapples but im scared it might slow me down.
Yee ive got a gcg hi flow so my car spools up quickly, but i found my car went the quickest when i got a bit of wheelspin other times i tried not to wheel spin.
I was in the rexy wagon dude, i think i got like 13.8 when i ran you.
I sure did'nt expect you to pull away hehe.
When you going next? i might pose more of a threat then :(
Nice going there man. It takes quite a bit of practice to get the most outta your car on the 1/4 with a manual car.. My 60fts are always 2.4 so I need more practice..
Make sure you get a 12 next time you head out :)
yeee i hope i get a 12 nxt time jst keep my 60 ft down.
bmxwrx: Im going back in couple of weeks coz my mates taking his xr6t in for mods. He ran a 14.3 in auto last night and wana see the difference after the mods. Your cars a sleeper looks stock standard what have you done to it? Im hoping to do a few little mods before i go out next, suspension etc.
I'm running untuned atm with bigger turbo, top mount cooler and 3" zaust. Getting tuned soon, so next time i hope to be in the 12's with ya, gotta get a good jump tho :D providing my clutch is still good for it hehe
Was 14.3 stock for a xr6t? Those whales can get moving real fast once fiddled with, i'm sure you'll find out soon too.
Let me know when you going next dude, we'll have a chat next time.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
