As said before i made 225rwkw at 16psi boost. It was my first time at the runs and only like the third or fourth night id taken my car out since modifying it, so im still not used to the launch.
Anyway 3 out of the 4 runs I had I got in the 13.1 bracket. My final run i was spewing my third wouldnt go in and i was driving the best!!!!!!
Best Time:=
60' 2.175
330' 5.741
660' 8.605
mph 86.82
1000' 11.077
ET 13.142
MPH 106.44
KM/h 171.3
Final Run (Missing third)"=
60' 1.948
330' 5.478
660' 8.632
mph 81.06
1000' 11.206
ET 13.342
MPH 103.02
KM/h 165.79
Im pleased with the results but what time do you reckon i could of got if I didint miss third according to my 60ft etc?
https://www.sau.com.au/forums/topic/65587-my-results-first-time-at-runs/
if you hadn't missed third and managed the same trap speed as the other 13.1 run, with the 1.9 60" time.. you might have got a 13.00 or possibly just in to a 12.99 area.
what wheels/tyres?
how much tyre pressure did you have?
what suspension?
16psi boost? what turbo?
nice work for your first outing..
will get much better as you get used to it
  bmxwrx said:
Hey dude, i was next to you in the 13.1 run. Not fair you got more boost than me :(
What car where you in what time did u get?
Ive got 17inch mag wheels on my car and i put the back to 20psi and front i left basically normal. My cars got cut springs, i wana buy sum pineapples but im scared it might slow me down.
Yee ive got a gcg hi flow so my car spools up quickly, but i found my car went the quickest when i got a bit of wheelspin other times i tried not to wheel spin.
I was in the rexy wagon dude, i think i got like 13.8 when i ran you.
I sure did'nt expect you to pull away hehe.
When you going next? i might pose more of a threat then :(
Nice going there man. It takes quite a bit of practice to get the most outta your car on the 1/4 with a manual car.. My 60fts are always 2.4 so I need more practice..
Make sure you get a 12 next time you head out :)
yeee i hope i get a 12 nxt time jst keep my 60 ft down.
bmxwrx: Im going back in couple of weeks coz my mates taking his xr6t in for mods. He ran a 14.3 in auto last night and wana see the difference after the mods. Your cars a sleeper looks stock standard what have you done to it? Im hoping to do a few little mods before i go out next, suspension etc.
I'm running untuned atm with bigger turbo, top mount cooler and 3" zaust. Getting tuned soon, so next time i hope to be in the 12's with ya, gotta get a good jump tho :D providing my clutch is still good for it hehe
Was 14.3 stock for a xr6t? Those whales can get moving real fast once fiddled with, i'm sure you'll find out soon too.
Let me know when you going next dude, we'll have a chat next time.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
