Chris32 may be able to be of help as he is running GTR injectors.
You could work back the calc and find out the lag time via his compensation values.
I too am interested in the stock specs as I am about to fit larger injectors to mine.
With power FC for standard injector's you just set them back too 100% and 0.00ms as long as its a RB20 PFC.
Yep thats a firm....
And this is using the PFC calc for GTR LI type. Treat as base point only. Remember these modifications should only be carried out by a qualified technician.
Press. Timing Lag Flow
@ 2.55bar 0.579 -0.15ms (440)
@3.05bar 0.577 -0.12ms (485)
@3.55bar 0.580 -0.14ms (525)
TT
thanks targa for the info.....so at base pressure if i put the injecotors in and use 61% injector compensation on all six injectors and change the lag to -0.15 , it should be ok to crank over and idel half decent??
So is it fair to say, that the rb20 270 cc injectors have a lag of 0.922ms campared to the gtr 440 injectors which have 0.772ms at base pressure???
Also i put my pfc in last night with the stock injectors, its starts but idle is rough as guts. I did the recommended things from the manual....let it idle with no electrical load......then with the demister on.....then with a/c.......but it was still rough as. Anyone got some tips?? also it had a huge flat spot at 2000rpm. I wanna be able to drive it from home to the tuner.
i just wanna have everything ready for the tuner so all he has to do it tune it when i get the car there.
Cheers
hey cubes.....i didnt initialize it, as it was brand new out of the box....but i'll hook it up again and see how it goes....all i did was switch the boost option off and start the car from there.....
when u intialize do u switch the car off then back on???
Not having a go at you dude, but why not just drive the car to the tuners without the PFC, pull up out the front, lean over and plug it in and tune it. Im sure you can cosmetically fix things up when you take it back home i.e. put kick panels back etc etc.
yogi,
Yep, when you initialize you then switch off the ignition and back on again.
When I initialize mine it sets the boost control option automatically off.
If you need to compare any base ign,fuel map settings let me know and i'll take them down and post them up.
If you have warm starting issues drop in another 5ms in to the cranking section of the settings menu.
From memory 80+degree's defaults to 4ms. Set this to 9ms, continue adding 5ms until you get down to around 30degree's or what ever it is.
Cold starts on mine were perfect, just the warm starts that were a bugger.
Thanks for the help cubes.....i will give it another go tommorow and let yas know how it goes. :D
Hey sproosy the only reason i need the pfc to goto the tuner is because the car is having 440cc injectors and resistor pack installed. The car will run like a bitch with the stock ECU and the 440's, if it runs at all.
Cheers
As the other guys said - stock injectors, just set the values back to zero
When I installed my 440cc GTR injectors and resistor pack, I started it with the stock computer, as I figured if it was wired wrong, I'd rather torch a stock ECU than the PFC. It started first crank, but as expected, ran as rich as one of those big ass racing trucks :D
Also did the same with the Z32 AFM, it started ok as well
One thing to all 32 PFC owners, when you get it tuned, make sure the water temp correction settings after 60 degrees are set to 0.00, otherwise your car will detonate if your water temp starts to rise. Found this out at a track day, as my car was always at about 70-75 water temp when it was tuned.
After a few blasts, the water temp would get up to 80-85, and due to there being water temp correction (making it slightly richer up to this point) adjustments up to 75 degrees on my car, after it got a bit hot there was no correction, and hence the car actually leaned off and started to detonate.
Its not hard to fix, just that with the correction on, the injector map isn't a true representation of what is being measured on the dyno, as its taking the injector map and adding fuel for certain water temp values. Of course, this is needed for cold start etc, but once your car is up to running temp, there is no need for such correction
Targa Tom, any joy with interfacing a GTR air temp sensor? I heard with FClogit, there is air temp correction, which would be bloody useful if you could interface a air temp sensor
Chris
i was looking at doin this too chris....trouble is tracking a GTR air temp sensor first (or buy a new one)
Interesting to note is my PFC is using a q45 afm (and is set as a std r32 one) and has 550cc injectors installed, but has no injector correction, or lag time set....Got me confused how it runs, but its not been properly tuned yet by Shaun...
odd, you'd think it would run like a pig
the injector correction is for when its running in closed loop, lag time i am not sure about, just set it to what I was told to set it too what it is now
I guess Shaun just tuned around all these things?
yer...he did a damn good job, because he couldnt get it to idle at first, then add the larger afm, and the pump / injectors for the run in. I then went for the power tune, and the damn muffler is too small (from a reputable exhaust shop in the city) so i had to upgrade that too....
Just waiting to get it fitted, then im back into see Shaun. It does run perfeclty well however setup as it is (apart form a slightly high / hunting idle (aac me thinks))
Go the straight thru 3.5" like I got done mate :D Guaranteed to wake the dead. Only the rear 'muffler' if you could call it that!
Mine back in next few weeks fingers crossed
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
    • I might have gone a little more South Efrican.  But this is off topic.   😍😍 FD 😍😍
    • I think you might have skipped a whole vowel sounds there C.
