i jumped into my car this morning turned the key and to my shock the car was shakeing and spluttering all over the place, i gave it a rev to stop it from stalling because on idle it just dies i checked all conections and hoses there ok changeing
sparkplugs tonite. any other ideas the black smoke is makeing me sick realy.
https://www.sau.com.au/forums/topic/65597-r32-wont-idle-black-smoke/
i cleaned the air flow meter and tested it the car started but with the same result black smoke and spluttering i also cleaned the (acc) aac valve what ever it's called looked fairly clean i removed the plugs and looked at them all of them had blak soot on them. do you guys think my afm is stuffed or somthing else irridums go in tonite
yeah.. I'd say 90% likely to be AFM. AFM controls idle mixtures, so if it's buggered will blow a heap of black smoke, idle irregularly, etc.
A clean might not be enough to fix it. You'll have to try swapping in another one and see if that fixes the problem.
I wouldn't bother with the irridiums, and save the dosh towrds the possible new AFM... that is unless you really were thinking of putting irridiums in anyway.
  • 1 month later...
hey all. i have the same problem with my GT-R32. it happened all of a sudden last night, so i did a search to see if i can self diagnose the problem my self.
on cold idle its fine, but after a few mins it starts to spalter around 500-800 RPM, with black smoke out the exhaust. is this the same problem? and to fix it, is this the same?
thanks
JUSTIN
chears mate... im not into all this mumbo jumbo stuff... but im learning, and for a muscle head like me, i think i know a little.... i have twin airpods and im %99 sure i know where the AFM is located. and cause of the twin airpods, ill have twin AFM's right?
BUT as for the "air flow regulator," whats he look like, and where is he...?
i have wednesday off work, so i plan to pull it all apart give it a decent clean. and i am ment to use break cleaner. thats what its called right?
and as for the coil packs, and spark plugs, i plan to get a full survice done, oil filter relocation and cool kit fitted in about a week... just waiting on payday.
thanks for the help so far.
JUSTIN
ok... get this.......
my car is still doing the same shat. so put it all back together, and left it for a few days. this morning i popped the hood, unclipped the clips that clip on the AFMs and started it up....
Fine. idles the same as before i had the problem.
i let it sit there and idle for a while, jumped in and took it down the street, BUT i couldnt get boost. is this because i unplugged the two plugs and it wasnt reading it???
any-way, i took it home, popped the bonnet, plugged in only one of the clips while it was still running, and the car started to idle real low again. then stalled about 3-5 seconds after plugging it in.
so i unpluggerd it, started it up, and plugged in the secnd. the same resault.
unplugged it, started it up with out the plugs in, and it was fine.
WTF is up with that? have my AFMs shot them selfs??? or have i shot them...
one more question.... whats the difference between an "Air Flow Meter", and an "Air Mas Meter" ??? they both measure the air that comes in right?
Air flow meter is more commonly known as being the kind that have the flap inside and the needle that reads the flap's position. Air mass meter is more commonly the hot wire kind that measures air as a mass. You have an air mass meter. They can be referred to as either but technically that is the difference.
all good now... last week, i had a few days off work, and had a decent look behind the front bumper, and to my suprise the intercooler plumbing blew off!!! yeah thats right - off!!! so i put it on, plugged in the AFMs and off i went.
that was a relife. i thaught i was going to fork out a couple of hunderd bucks to get something fixed which i could have done my self.... which in the end i done my self anyway.
thanks for the help tho.
JUSTIN
