:wassup: Hey guys, I'm new here and have just bought an 89 R32 GTS-t 4door. It's great even though it's been at the mechanics getting complied since i've had it, i just can't wait to get it and go for a drive.
My question is: I'm looking at putting an alarm system with an immobilizer in to the car, put i'm not sure of how this can be done so i can still use a turbo timer? Is there a way it can be wired that the immobilizer wont kick in till after the timer shuts off??
hope someone can help?
Cheers,
Yes there is. I'm told that all you need is an extra two relays - one to cut the immobilisers, and another to cut the ignition signal to the alarm (so it doesn't go off). I have NFI how they'd need to be wired in (I'm an electronics noob), but a mate of mine who does this kind of thing for a living mentioned this a while back and said it was a fairly simple thing to do.
Yes it can be done so that the immobiliser/alarm and turbo timer work together. My brother has such a setup in his Evo. He has a Brant system as well as a Apexi timer.
I heard from a Brant contractor that some timers are harder to work with than others. He said the easiest were Apexi and HKS and the hardest were GReddy and Blitz.
You can also do it without relays... I have an immobilser, alarm and turbo timer. But you have to lock your door with the key. When you turn off the ignition, the turbo timer will allow the car to continue running, therefore the immobilser thinks the car is still on and wont engage until the engine stops... that's providing your immobiliser self - engages. :)
Many of the immobilisers these days are turbo timer compatible.
With mine (Mongoose I think it is), with the engine running and the doors locked, any attempt to open the car (or drive it away) will result in the alarm going off and the immobiliser cutting in.
Thanks strutto but i tried a few searches for keywords and couldn't find much information.
Did you post anything much different to what the guys have said above??
Try this one mate:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=20950
Thanks for that strutto. I'll be getting my alarm in a week or so. and hopefully the car as well for that matter. The mechanic got sent the wrong seatbelts for doing the compliance and i'm stuck waiting for them to come in. Doesn't that suck.
So hopefully i'll get everything and it will all go well.
Everyones help is really appreciated. Thanks for your input. :(
Hey thanks johhno,
I'll be installing the alarm soon. I started on the stereo on the weekend, and then got pulled up with the antenna adapter. And guess what, no on in Hobart has one. I've ordered one over the net that should be here tomorrow, but i'm not happy. :cheers:
So how did your alarm turn out, everything working fine?
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
