i have them, there is a review on here somewhere, do a search for it.
i've done 3 track days and nearly 15,000ks on them and they are still fine, maybe 50% tread.. hard to tell... road noise is fine. Good road tyre. i have 255/35/18's
https://www.sau.com.au/forums/topic/65627-hankook-k104s/#findComment-1226043
I run 235/40/18 fronts and 265/35/18 rears. Currently have about 15-18,000kms on them and they seem to be holding up fine, heaps of tread left. No track time on them yet but for the money they are pretty good. No louder than any other street tyre I've used in the past.
Z.
https://www.sau.com.au/forums/topic/65627-hankook-k104s/#findComment-1233035
  • 6 months later...
Just bought four 235/45 17" Hankook K104s, since everyone is raving on about this particular tyre.
I havn't yet tested them in wet conditions but they seem like a very comfortable drive, and arn't noisy.
Got them from Jax, rang a few different stores and they all varied in prices! some had the tyres for $30 more!.. Got them for $169 each after some negotiations biggrin.gif also did my wheel alightment front and rears.
Seems like a good tyre so far.. they are rated Y grade and have silica compound too!
https://www.sau.com.au/forums/topic/65627-hankook-k104s/#findComment-1595506
Z.
What did the 265/35R18's cost per tyre if you dont mind?
https://www.sau.com.au/forums/topic/65627-hankook-k104s/#findComment-1595692
When i bought my hankook ventus k104s the guy at the shop said hankook had been doing a lot of work to improve their sidewalls.
Mine have lasted 20000 kms very well so far, and ive hit many a pot hole.
https://www.sau.com.au/forums/topic/65627-hankook-k104s/#findComment-1615400
ive heard tyre places that sell Khumo's say they are crap! but ive driven on the ecsta supra's and the k104's, and i have to say that for the price of these tryes, both brands perform extremely well, and by no means are you going to jump up and say "these are cheap tyres!" if someone handed you the keys to the car without telling you what tyres are on the car.
https://www.sau.com.au/forums/topic/65627-hankook-k104s/#findComment-1631432
Hi Guys,
I have heard great reviews on this tyre and thinking of getting this sometime this week.
I do have a few questions tho. Sorry to steal the thread!
I have 18x8.5 for fronts, 18x10 for rears. For rears, i was thinking of getting 265/35/18. But for the fronts should i get the same sidewall size ie should i get xxx/35/18.
Would having a different sidewall at the front and back, ie, fronts being 40 and rear being 35, make a big difference esp to the tacho, mileage and handling?
The two sizes in 35s i was looking at were, 225 and 245. And in 40, there is 235/40/18.
What would you guys recommend? Would it make a big difference in terms of steering between 225 and 245?
Thanks heaps in advance guys,
https://www.sau.com.au/forums/topic/65627-hankook-k104s/#findComment-1633590
Hi Guys,
I recommend 235/40/18 on the front and 265/35/18 this makes the overall diameter of the wheels the same therefore your speedo will remain unchanged and your steering is not too heavy. It is the perfect tyre setup for a skyline.
https://www.sau.com.au/forums/topic/65627-hankook-k104s/#findComment-1664611
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
