WTD: Front bar for R32...
The 32 still sits untouched with the broken gearbox. So a little off topic but not worth having a whole new thread. The daily starlet has gotten back on the road after 9 months. Suspected blown HeadGasket at a track day resulted in a bit of scope creep rebuild. The motor got a full tear down, pressure testing, machined for MLS HG, ARP head bolts, new bearings, all new seals etc also noticed some fatigue on the stock exhaust manifold so obviously the answer was a steam pipe manifold and highflow turbo. The exhaust was also looking tired with some rust holes. So I got a slightly over kill system made up consisting of Vibrant resonator and muffler with a highflow cat. The new highflow turbo had a larger inlet so instead of adapting the old intake got a case of the might as wells and had a nicer alloy intake made After the run in was finished i bought a (probably considered retro/vintage) EBC becasue "might as well"
Pretty stout result. How much boost? Anything left in it?
SAMSONAS Just saying U know and we know U wanna Just a matter of time....
This is kind of what I expected given the use case. I took my liners out for track days too.... It makes me consider just getting a diffuser and not bothering with the arch liners themselves. For the most part I would like to avoid water/mud/jank splashing up from under the car onto the bottom of the engine, lines, wiring, etc etc. (but brake ducts are cool too). Especially given this post on SAU here: Where it's implied you have to cut them because the actual tub is different? Which is pretty damn worrying because that is where the liners rub in a GTR with wider wheels... I definitely won't want to pay $2000 for plastic then cut them up. It also means said wider wheels rub on the tub in a GTT? FML. That said, I have found some evidence someone ran a 295/30/18 without scrubbing these liners. (and by extension.. the tub).
