Hi i have an r33 s2 skyline (auto), i have this problem that occurs once a while when i drive, but now its becomming more often. What happens is, when i accelerate and take my foot of the pedal the engine rev's will drop to 0 , when it drops after accelration the engine will sometimes stall and the hicas light lights up.
First of all the hicas light will turn on, then my car will loose all power (including brakes and power steering) and then the engine will shut off at a halt. This has happened to me in intersections and traffic lights so the car is to dangerous to drive atm.
Does anyone know the problem ? and where i could go to fix it ?
thanks for your help !
https://www.sau.com.au/forums/topic/65689-engine-dies-pls-help/
hicas wont make the car stop as it is your steering.
the reason your brakes and steering are tough is because when the car dies there is no power assistance so your brake booster will stay boosted resulting in your pedal feeling like it wont push in and your steering like it had no power steering.
the hicas check light always comes on in auxilary power which is what it is on when the car conks out as that is the key position .
do a search for this as many people have had similar problems.
but start doing the easy things first like cleaning airflow meter etc.
youll also find that the engine and oil light will pop on aswell as the hicas.
I had the same problem with my R32 Gtst..... intill i find out my head in my RB20det is bent and cooliant from the radiatior is goin through the pistons, droping in compression, which then changes sounds and the engine's revs drop and sometimes dies
ummmm... if its the common problem (sounds like it) alot of people seem to be getting this, its the AFM. i got the same problem with my R32 gts-t four door. only i havnt got the cash to get another AFM. take a look at "engine cut out" threads.
Do you leave overdrive on or off?
I had the same problem as you (see: http://www.skylinesaustralia.com/forums/sh...ead.php?t=65491 ) but when I turn OD off it cures the problem. I just turn OD on when I'm cruising at 50kmh+ and when I goto slow down at lights I just turn OD off to get the RPMs up again.
Note I also have a BOV but it's plumback.
I also learn to give it more throttle around turns (as that's when the stalling usually happens).
yeh i noticed that it helps with Overdrive off, but still i dont want it to stall at all. Another thing is when i go up hills when i accelerate and then let my foot of the pedal, it will def stall. It getting annoying thats why i wanted to see if anyone else had the problem ... ill try the bov first, if it doesnt ill just crash it into a pole lol j/ks cos its reallly pissing me off.
The plumbing from your original standard BOV should be still hanging there so hook that up and get some brackets to secure it so it doesnt leak and I bet your problem is solved. Basically your AFM gets tricked when your Bov vents and thinks that your throttle is still open therefore it momentarily runs rich and stalls the engine. I would imagine it might be worse on auto cars as you dont have as much control on gears shifts.
PS get a manual :headspin:
hmm i have a small rubber tube that runs from the BOV to the engine part ? is that the tube your talking about ? if so, it's already connected
yep sounds like it, I think it connects to your inlet pipe from your afm/air filter, just reconnect that if you can, if you cant buy another BOV that will, youll lose the sound but whats more important...performance or rice.
I would be checking the following.
1. Any vacuum leaks in piping/plumbing/emmision hoses etc.
2. No atmo venting BOV valve, is it set right (better still fit original item)
3. Disconnect the AAC valve connector and make sure the base idle is set correctly.
4. Make sure the idle contact on the TPS sensor is working as it should.
5. Check to make sure the idle voltage on the other TPS is measuring <0.5V at idle.
Im sure it will be one of the above.
It won't just stall for no reason...
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
