Have you ever heard that cross drilled brake rotors crack? Here's the story...
Hi all, after speaking with DBA (as I need new rotors) I thought I'd ask why cross drilled rotors are only recommended for "street use" because I know a lot of people wonder why this is the case and what will suite them. The E-mail reply was as follows...
Question -
"Just one more question. I know that cross drilled are not recommend for track use, is this because of the weakening effect on the rotors or is it more a liability thing? I have heard of cracking of the discs but realistically what sort of braking are you going to have to be doing to cause this?"
Reply -
"Adam,
the reason why we don't recommend cross drilled rotors for racing or track work is due to the following:
The disc rotor face surface area is reduced due to the holes and as a result this face heats up faster under braking.
Once you release the brakes the rotors cool very quickly due to the holes.
Due to this rapid heating and cooling of the rotor face it is possible for the rotor face to sustain what is known as heat shock.
Because the rotor is unable to heat soak and dissipate heat evenly the face of the rotor can develop cracks around the holes.
The use of slotted rotors allows the disc to heat soak and cool more evenly so the rotor is less prone to suffering from heat shock.
Heat shock can be evident in cross drilled rotors even when used by an extremely energetic driver on the street. If the drivers driving style is fast with rapid jabbing of the brakes and exallerator pedals he/she will be more likely to have problems with cross drilled rotors. Due to this reason we recommend the fitting of cross drilled rotors for looks only and improved braking performance under normal driving conditions.
I hope this answers your question, but if you have any further queries please feel free to email me.
Kind Regards,
Aaron Franklin
Technical Sales Advisor
Disc Brakes Australia Pty Ltd"
Thought this might be some helpfull info!
so is it safe to assume from that that cross drilled AND slotted discs will be less prone to this?
"The use of slotted rotors allows the disc to heat soak and cool more evenly so the rotor is less prone to suffering from heat shock"
The cracks would still form around the cross drilled holes inark beacuse the change in temp would still be significant. The only way to go on the track is slotted. Do they make 5000 series for the 34 yet adz?
I failed my RWC for the first time because I had drilled rotors with 1cm - 2cm cracks on each hole nearest the edge of the rotor... they looked sweet but the funny thing was I passed my Engineerring Cert. but not the RWC.
From what I've heard the DBA rotors were drilled after they were fabricated? While the Porsche and other high-end rotors had the holes cast from factory?
Drilling post-fabrication gives less structural integrity doesn't it?
I could be wrong though..
Because they aren't $200 rotors like DBA are...
HAHA good point.
so in other words his statement is only relative to DBA rotors... not in general
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
    • Haha, the big brain move is to buy a second set of headlights to clean up or retrofit. I definitely don't have one sitting in a cupboard that hasn't been touched since it arrived. Just have to ignore the intrusive thoughts that suggest the second set is not quite as good as it could be and to buy a third set that the job would definitely get done with
    • Nah I'm talking about the GTS-t with 15" wheels and single piston brakes.  I've seen them pop up occasionally over the years. You can see it in the brochures. Most were early models (aka Series 1).
    • Oh man... I've been here, that's for sure. I love my ugly but still functional headlights that can never come apart again.
