Never inject water or anything post throttle body unless you're doing direct port injection...
There is heaps of information on this on the internet, I have a CAPA based system on my shelf in my shed, not going to fit it to my R, probably a bunky. The thing is always that the volume that you displace by the water needs to be taken into account by adding more fuel. Another thing to note is that just injecting water will actually make you lose power, unless you use extra advance or boost..
Research.. Like I said, heaps of information on this on the net.. While you're at it, look into Toluene addition to your fuel, it is by far a better option, but once again, you must run extra advance or boost to gain any increase in torque/power..
http://www.designengineering.com/products.....asp?m=sc&cid=1
Check out that link. Its a system that uses Co2 as a cooling medium. Basically whats inside a fire extinguisher. Only costs about $20 to fill the bottle and its not flammable.
A friend has purchased both the intercooler element and the bulb for inside the intake. Will have results when its installed.
Looks very interesting.
well i think the water spray onto the intercooler is a good thing. But am 100% against water injection, true it will let you run higher boost with out pinging but it doesnt make any power its self where as methonal would. even a methonal water mix is better. and iv always sprayed after the turbo b4 the tb.
Spraying water before the turbo is soo wrong, water forms droplets that are as sharp as diamonds, great if you want to grind down your compressor wheel slowly, but that is your choice to make..
The best Water/Methanol mix is 50/50, I used to run a water/methanol mix when I was running in engines to keep the intake charge as cool as possible, used to remove it once run in and only ever refit if I wanted to get some extra advance..
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
