I have an r33 rb25de head on my rb30 ( na of course ). cams and head stock , xf falcon t/b , 10.5 compression , extractors . 3.7 diff non lsd . kw unknown . best 1/4 mile 14.7 @ 92 mph . weight i think is about 1360 kg ( 1987 r31 skyline wagon )
  • Replies 64
S13 Silvia
ENGINE   WEIGHT  POWER  TORQUE  (0-100km/h) (0-400m)
CA18DE   1090kg  97kW      162Nm       9s               16.9s
SR20DE   1110kg  105kW    188Nm       8.6s            16.6s
CA18DET 1120kg  130kW    225Nm       7s                15s
SR20DET 1170kg  153kW    274Nm       6.2s            14.5s
R33 Skyline
RB25DE     ??        140kW    230Nm       8.1s            16.21s
RB25DET 1370kg  184kW    294Nm       6.21s          14.4s
R32 Skyline
RB20DE     ??        116kW    184Nm       7.63s          15.76s
RB25DE     ??        142kW    231Nm       7.1s            15.0s
RB20DET 1290kg  160kW    263Nm       6.9s            14.8s
Does anyone know if those are correct?
According to that an RB20DE (Non-turbo) R32 is quicker than an RB25DE (Non-turbo) R33??
I know the 33's are a bit heavier than the 32's but I thought the extra power in the RB25DE would still make the R33 quicker?
Does anyone have accurate times and power figures for these cars?
not accurate the rb25de is 147kw @ 6000 rpm and the 1/4 mile time is quicker than 16.21 im pretty sure it was around 16 and high 15s but theres no way a r32 rb20de is faster than a r33 rb25de , the r32 rb20de doesnt even make 90kw at the wheels...
All this is makeing my 15.9 R31 sound pretty quick in terms of NA skylines.  Who would have thought the least sportiest of the skylines could be one of the fastest.
Thats because in my opinion, the RB is nissans best line up of engines ever. anyone care to disagree??? :) :wassup: :cheers:
R33 GTS25 - 147kw (200hp)/1470kg (stock) - what's the VL RB30E engine rated at stock?
IMHO the GTS25 is not a bad buy if you want a simple cruiser without the hassles of a turbo. Just avoid the 2L GTS model, though I don't think there are many of those in Aussie.
i got this off rbforums.com
RB30E
Capacity - 2.960L
Induction - EFI NA
Valve Train - Single Overhead Cam
Bore x Stroke - 86.0 x 85.0 mm
Compression Ratio - 9.0:1
Maximum Power - 114kW @ 5600rpm
Maximum Torque - 247Nm @ 4000rpm
RB25DE
Capacity - 2.498L
Induction - EFI NA
Valve Train - Double Overhead Cam
Bore x Stroke - 86 x 71.7mm
Compression Ratio - 10.0:1
Maximum Power - 140kW @ 5600rpm
Maximum Torque - 230Nm @ 4800rpm
The VL has more torque (obiously, bigger displacement). I reckon it would be a close run but i guess it would all come down to driver ability......
Thats because in my opinion, the RB is nissans best line up of engines ever. anyone care to disagree??? :( :wassup:  :P
VH-VK series is hands down the best... many other engines capable of making up to and over 1000hp NA... oh they just love boost too :headspin:
edit: on pump gas, daily driven :)
nah i own heaps of things with my Little 2 L its a lot faster then i thought it wood b
I can't see a Rb20de Beating me But the r32 Rb25 wood go Hard i think
Man your cars auto, i've absolutly spanked an auto sr20de silvia in my non turbo R33 manual RB20E!!!!!!
Thats a 2L single overhead cam Rb
So i'd hate to see how your auto sr20de would go against an rb25de, or even an rb20de.. they'd rape u
A good rb25de will be able to run a stockish silivia ca18det..
What's the differnec between a type S and type M r33?
Type M applies to turbo models - R32 type M's had better brakes and few extra goodies. In the R33 series all turbo's are Type M.
Type S applies to non-turbo's, not sure about the difference in the R32 series but for R33's (GTS25 only) you get 10 extra HP, standard HICAS (I think) and a few other extras.
Have a look here for more info:
http://english.auto.vl.ru/catalog/nissan/skyline/
Timmays old R31 5speed GTS stocker ran a 15.1 sec 1/4. :rofl:
Not a bad effort, watching the run was quite funny, really hard chirps in to 2nd and 3rd.
Almost as if he was going to rip the shifter out.
Don't let peak power fool you ppls.
Its the area under the curve and torque that accelerates a car.
Guest jimmyd17
15.1     That is amazing.   Poeple on other forums are laughing at anyone who say thier R31 can beat a stock auto VN commodore.
i do believe he said it was a GTS skyline.. so depending on if its a SI/II or SIII from memory i think they have 130kw and 140kw compared with the 118kw of the normal R31.. so yes, a GTS R31 should beat a VN commodore u would hope. having said that, i have a VN berlina auto wagon and it leaves my mum's GXE R31 5 speed for dead.. both are stock. VN wagon: 0-100 best: 7.94 (timed with stopwatch accurately) on a cold night (makes almost a second difference compared to a warm day).. 3/4 tank normal unleaded and able to get consistent mid 8's.. with the 7.94 i got heaps of traction with the auto stalled up (good road surface)
both the R31 and the VN seem to have quite similar power in high revs despite being totally different engines.. they both pull about the same up top.. but the low down torque of the VN gets it moving up to the top revs a hell of a lot faster. but the RB30 is so much smoother compared with the old buick rattler lol. :wassup:
I use to have a VN manual V6 these are probably the fastest of the the V6 commodore range the VS's-VT's couldnt get near it. I had Extractors, twin cats into a 2 1/2 exhaust, pod and a powerchip gold 98 chip. It used to fly for what it was I miss the rattly old beast.
We timed it at 7 flat from 0-100 traction being the main problem no LSD so 8s and 8.5s wearnt uncommon.
Guest jimmyd17
yes i agree.. i think the VN's would be right up there in terms of the fastest V6 commodores. i would be interested to see how the VN lined up against a new VZ alloytec 175kw in a 0-100 test. i reckon it would definately give one a run.
here is a quote from AutoWeb doing a review on a VZ acclaim wagon:
"The 0-100 km/h time we gained (car unladen, one person, low fuel) was about 9.3 seconds 0-100 – certainly nothing to write home about. But more important than the bare number is that on the road, the car never feels particularly punchy. The new engine has a very flat torque curve (ie there’s higher than usual power available at all revs), but the absolute torque output isn’t very great."
source: http://autoweb.drive.com.au/cms/A_2391/article.html
i worked out that the VN wagon has 8nm of torque more PER TONNE, than the VZ alloytec wagon.
so one would have to guess the good old VN wouldnt have too many problems leaving behind a VZ auto wagon considering the approximate tested figures are over a second in favour of the VN. but what would come out on top if it were a VZ SV6, 6 speed manual 190kw?
here is a quote Drive doing a review on a VZ SV6, 6 speed sedan:
"The SV6 can't match the Falcon's off-idle grunt but it pulls well from about 2000rpm, cruises easily and with great economy on the highway limit at only 1800rpm in sixth. The zero-100kmh trip takes 8.3 seconds - slower than the Falcon, but fast enough."
source: http://www.drive.com.au/editorial/article....px?id=8916&vf=1
i guess all the newer commodores have progressively gotten heavier and i reckon slower lol.
hrmm I'm pretty sure it was, the Timmay in Adelaide, Red R31 that he has now sold? :rofl:
My other half just said it wasn't.
I'll have to check the vid.
With regards to the VN's I've found it to be like this.... :(
VN Auto - Slower than a VS II Auto
VN Manual - Faster than a VS II Manual.
The VS's manual gearing sucks. :D
I had a VL Commodore with a 2.5" & extractors. It was quite a bit quicker than a friends VN that had a 2.25" and also quicker but only slightly than a friends VS II.
The VS series 2 ecotec's really got up and moved, well for what they are. :)
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
