  • Replies 64
  • 3 weeks later...
i had a rb 25de out of a r33 in a r31 aussie skyline and it was auto it was not so quick as vl's and r31 rb30e took off better at the lights but you did come crawling back in 2nd
i now have a rb20det 92 year motor and 5 speed box etc
i never took it to the drags i did thoe drag a mazda rx7 series 2-3 with a 12a brige port and 51 mm carbies etc and exhaust tec zorst when hard but i came back hard as only when i got second gear and the revs up
Guest jimmyd17
R33 RB25DE auto's are SLOW off the line.. they go fairly well top end, but i had a go at one yesterday in my work car which is a bog stock auto VN V6 dunnydore station wagon with roof racks and i absolutely left it standing by a number of car lengths up to 100k's before we backed off.. and i heard it wind right out in first and change into 2nd full throttle so it was definately going.
ill have to agree. u just cant get the low end torque without using the gears in the auto rb25de. They are a disgrace to skylines, i realli dunno why sum1 would wanna buy a auto na skyline. and dont gimme no BS abt them not havin a manual liscence because they shouldnt even be allowed to drive a skyline if they want an auto AND non turbo.
  • 3 weeks later...
i like to see how a Gts R32 or R33 wound go vs my Silvia Q Sr20de
Siliva 1150kg 105kw or 115kw not sure stock
Mods Pod exhaust
Gts R32 1270kg with Rb20de 116kW@6400rpm
gts r32 1270kg with rb25de 134kW@6000rpm
Gts R33 1320kg with rb25de 134kW@6000rpm
My sr revs to 7500 what to rb rev to
I think i can take the R32 with a rb20
but the rb25 seem to have a bit of power in them
Mods Pod exhaust
R33 GTS25 coupe is 147kw @ 6400rpm/1330kg (in Type S form):
http://english.auto.vl.ru/catalog/21695/
Redline is 7000 rpm.
So you might struggle a bit vs a GTS25 type S?
you would get owned, i rape my mates sr20de sil all the time. it barely beats excels. athough i think his does need a tune!
rev limiter at 7500, peak power at about 6000
nah i own heaps of things with my Little 2 L its a lot faster then i thought it wood b
I can't see a Rb20de Beating me But the r32 Rb25 wood go Hard i think
My Sr20 has a good tune
Most of my mates turbo Sr Own R33 the turbo give them both about the same Power gain
cause a Stock turbo R33 is like 187kw
S13 silvia is like 156kw
and the silvia is faster most of the time due to the weight
S13 Silvia
ENGINE WEIGHT POWER TORQUE (0-100km/h) (0-400m)
CA18DE 1090kg 97kW 162Nm 9s 16.9s
SR20DE 1110kg 105kW 188Nm 8.6s 16.6s
CA18DET 1120kg 130kW 225Nm 7s 15s
SR20DET 1170kg 153kW 274Nm 6.2s 14.5s
R33 Skyline
RB25DE ?? 140kW 230Nm 8.1s 16.21s
RB25DET 1370kg 184kW 294Nm 6.21s 14.4s
R32 Skyline
RB20DE ?? 116kW 184Nm 7.63s 15.76s
RB25DE ?? 142kW 231Nm 7.1s 15.0s
RB20DET 1290kg 160kW 263Nm 6.9s 14.8s
Does anyone know if those are correct?
According to that an RB20DE (Non-turbo) R32 is quicker than an RB25DE (Non-turbo) R33??
I know the 33's are a bit heavier than the 32's but I thought the extra power in the RB25DE would still make the R33 quicker?
Does anyone have accurate times and power figures for these cars?
    • Oof. One of my mates has an R34 GT-R that he initially was a "I want to go twins for response and convenience" on his stock 2.6 with Kelford 272 cams, but his friends are pests and were always in his ear about their place being in the bin.   Eventually one of the 2860-5s decided to add it's own input and force his hand, so he conceded and went for a Pulsar 6262G ("G35 900") with T4 0.85 hotside.    Here's an overlay of the results, same cams, same stock bottom end, same boost, same fuel, just from a pretty tidy 2860-5 install to a Pulsar turbo on a 6boost maniifold on BP98.   Worth mentioning here, it may seem like a dead horse thing but the dyno plot doesn't tell the story of how much better it is to drive - transient response has completely changed the car, he used to have flat foot shifting to stop it having to wind up again on gear changes even at >7000rpm... now it builds boost faster than that even short shifting.   It's 100% transformed the car before you even consider how much better it holds on: Pulsar and Garrett aren't the same, but from our experience if you're just looking for a better drive and the ability to make the same or more power I think the divided G30 770 would probably be the smallest I'd go to.
    • Great work Duncan, any events local you will give it a test once all done?
    • Sweet, yeah hoping stock gears will hold up. May use the transbrake feature on hill climb starts so that will test it.
    • Yeah, the thread is only nearly 20 years old.
    • Been down in Tassie for 2 weeks (a cruise, not a race for once) but spent a little time on her when I got back. I worked out the injector settings in the PowerFC were not correct for nismo 555s, set those to 66% +10ms and added a little air at closed throttle, set the timing (approximately, because it has some weird non 15o cells around idle) and now she starts and idles properly. She purrs like a kitten (ignore the co2 alarm in the background, I did  ) 20250518_171052.mp4 Next step, off for run-in, tuning and alignment!
