there are no earths in a car only positive and negative so the negative is the go
your car is not earthed in no way does it touch the ground it is insulated by the tyres
from a electricians piont of view which is me
The coil has 3 wires.
One will have +12V when the ignition is on, one will have -12V all the time.
and the third is the ignitor which is wired to the ecu/ignitor, depending on what coils you have. Series 1 coils have an external ignitor pack, while Series 2 have it build in directly in the coil.
Pin1 is the trigger from the ECU/ignitor
Pin2 on the coil is Earth -12V all times
Pin3 is +12V from a switched ignition source.
Hope that helps some.
