How much boost can an internally standard RB20 take. I am talking reliable boost, not how much before it goes bang.
The reason I ask is:
I was told when I bought the car that this block is extremely tough, so can handle the occasional high boosting. So, I have been running mine at 1.5 bar for nearly two years now. Just cause it can boost this high doesn't mean it reaches this every gear change. Far from it. I may actually only hit this boost once a month, but it is there when I want it.
Today I went to get my car dynoed. Came back $270 poorer and missing an extra 20 rwhp that I used to have and 0.3 bar of boost. He says I will blow a piston if I run it at this boost, but I haven't (yet). There is no detonation problems at 1.5 bar, and the fuelling is all ok.
Thoughts peoples?
So will my car die tomorrow if I wind the boost back up?
https://www.sau.com.au/forums/topic/6578-rb20-boost/
on australian fuel (98 octane) i dont thinky you should run over 1bar (14.5psi) with octane booster and the right tuning im sure 1.5 bar is possible but over time the engine will breather more and wear out due to such high boost levels.
im running my t04 at 14psi with a bigger pump and std injectors at 90% duty cycle
https://www.sau.com.au/forums/topic/6578-rb20-boost/#findComment-98067
Is the T04 the standard Turbo???
I have standard engine/turbo/intercooler with 3'' exhaust, Blitz BOV, HKS filter and Turbosmart Bleed Valve wound out to 0.95 bar. (14PSI)
The car runs fine and I love the boost response. I have no problems with running these sorts of pressures, but I am waiting for the turbo to say goodnight, so I can give her some real boosting!!!
My car is religiously serviced every 7500 to 10000 k's and she gets the good oil!
https://www.sau.com.au/forums/topic/6578-rb20-boost/#findComment-98185
Where did that come from?
Anyway, NIZ30, if you're running the standard turbo (a T3 derivative), at 1.5 bar, then you've been extremely lucky. The ceramic wheels are notorious for parting company with the shaft when run at much above .9 bar, and are often then ingested backwards into the engine. And the ceramic material is a wonderful cylinder honer.
https://www.sau.com.au/forums/topic/6578-rb20-boost/#findComment-98701
yeah i think you should leave the boost if you dont want any problems, if it was running fine then why did (whoever you took it to) wind it back? running 1.5 bar is too much for the factory turbo and you might not notice detonation but doesnt mean its not occuring. if you wanna run high boost get a FMIC, management, and an aftermarket turbo that can handle the high boost pressure
https://www.sau.com.au/forums/topic/6578-rb20-boost/#findComment-98705
I got all the things people are saying : -
Trust TD06-20G Turbo
Trust FMIC
Trust custom exhaust manifold (high mount turbo)
Trust Wastegate
Injectors (i think?)
Fuel pump
The car runs fine at 1.5 bar there is no problem with that. But can the engine withstand this boost?
Saying this, I am a bit disappionted with my 239hp considering the turbo I have. I need to sort out the fuel problem and think an Apexi S-AFC might be in order.
https://www.sau.com.au/forums/topic/6578-rb20-boost/#findComment-101774
I am pretty certain that the interanls should be fine on 1.5 bar, but it depends what sort of period you want to run this boost, as bigger boost equals increased engine wear.
You should check to see if you do have aftermarket injectors.
Going by the dyno results the fact that you dropped your boost pressure by .2 bar and only lost 20rwhp is good, as normally the rule of thumb is for every 1 pound boost you should make 10hp..? (correct me if i am wrong) so therefore you've dropped close to 3 pounds and only lost 20 hp.
Maybe you should look at getting adjustable boost so you can run say 1bar low and 1.5 high... I'm sure your turbo will be able to handle it, as well as your interanls, and you have a bigger pump so the injectors and some sort of aftermarket management is all you would need..
https://www.sau.com.au/forums/topic/6578-rb20-boost/#findComment-102085
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
