1992 NISSAN SKYLINE GTR GUN GREY (PRE SEVS) rego till May 2005
approx 92.000KS ,Black Leather interior,Twin air pods, gauge pod,Apexi(boost)/Auto meter(air/fuel) gauges
genuine Greddy inter cooler , Blitz sbc boost control,New engine belts inc timing(recently installed) ,O/S Giken twin plate clutch,(recently installed)
T2 carbon fibre bonet,jASAMA 3"exhaust ,Sard R2D2 blow off valves,Bomex front bar,17 inch deep dish wheels.
Apart from the above listed the car is in standard form and has never been boosted ,the controller hasn't been put in but most probably
will be installed , but will not be running with boost before sale is made.
looking to get $36.500 will listen to reasonably legit offers no time wasters or test pilots.
Please take into consideration this car was bought into Australia over 4 years ago .well before the sevs law came in so you will be assured that the car isn't the rubbish that has coming into the country as of late. Also note that the sevs laws
have now changed and if you want to get in with a good one this particular car is a good example of a what a Grade 4 should look like! The car and is close to imac , It spends most its time locked in garages and close to never been driven.
Any expection or tests welcome but will not be taking people for "drives" unless they give some concrete show of interest in the purchase.I will say that
2 things need ironing out and that is it needs a wheel alignment (that probably will be done before any expection , compression test needed (also might be done before viewing) and rear wheels have yet to be polished
in chrome , something i never got around in doing . Apart from that its a regretful sale. The reason ?... well basically i need to get $$ to save for a roof and settle small debits still pending.
for more information or to make time for a viewing.
pm or please email
[email protected]
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
