hey all,
it is time for me to sell my rig and move onto something new,
so for sale,
1991 S13 silvia with onevia conversion.
engine: redtop sr20det.
auto.
mods:
engine:
-giwasa intercooler
-custom 3" turbo back zorst
-turbosmart dual stage boost controller
-bosch 040 fuel pump
-apexi safc II
-blitz pod filter
-greddy BOV
suspension/brakes:
-tein HR rear coilovers
-lowered king springs at the front
-new front brake rotor's
-cusco strut brace
wheels:
-15" forged volk racing wheels (mesh style)
with 205/60 on the front with 90% tread,
and 215/60 rear with 80% tread.
interior:
-autometer boost guage and air/fuel guage
-momo sports steering wheel
stereo:
-pioneer mp3 head unit.
-clarion 6" front speaker
-clarion 6 by 9's in custom parcel shelf
12months reg and RWC.
car's body has just been panel beated and prepped for spray, arial has been shaved off and holes filled on front 1/4 panels,
so basically car just needs to be sprayed is will be lookin like brand new,
there is not a dint on the car.
asking $11,000 ono
if interested please call me on 0409415248 or pm me.
thanks matt.
PICS can be found at: http://www.nissansilvia.com/forums/index.p...showtopic=78571
https://www.sau.com.au/forums/topic/65820-fs-1991-nissan-s13-onevia/
hey all,
just had car fully serviced and front brakes done (new front rotors and pads)
so car is running 100% mechanically fine.
need to sell asap or will trade for r33 skyline must be 5 speed and turbo,
plus i give u extra cash.
so c'mon people.
matt.
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
    • I don't think he's got it on a gauge and on the ECU. I think he's got it on the gauge and on the HPTuners DAq thingo. Remember, we're talking about oil temp here, not something that the ECU is actually interested in for its own sake.
