GTR Turbo
jeje_6475
 Share
hi everyone..
I need some help here, I've own R32 GTR and I'm aiming to get around 350-400 kw at the wheels, so what kind of turbo should i get? I prefer the twin one though insted of convert to big single turbo.
What are you guys reckon about R34 N1 turbo? are they any good?
thx a lot guys
hi everyone..
thx a lot guys
n1s are great turbos and will be able to get you that much power and more,
but with that amount of power just remember you will need, bigger fuel pump, injectors, intercooler, radiator, at least a 4inch exhuast, twin plate clutch, computer, and just dont forget you cant run much more then 1.1 bar boost with the stock engine internals.
do you waat to see that power at the rear wheels or at all four?
if your happy with a bit less power this is a proven method a set of apexi power intake air filters, inteercooler, 100mm exhuast, fuel pump and twin plate cltuch you will have between 230-250 kw at all four.
im aim to get a set of n1s when the cermics to let go. there sitting at 1 bar boost
I'm yet to see anywhere near 400rwkw with N1s, of any form...
Also be careful when stock ceramic turbos let go a few of the guys have had their motors go with it when pieces of ceramic turbo let loose into the motor :D
What sort of motor have you got? How old is the car? How many KM? Whats your budget?
Guest
 Share
    • I am going to chime in here and say that is very bad advice for a built motor, making decent power of 400kW+ Especially if the rings have been gapped on the looser side. The more power you make the heavier you need your oil to be to be able to maintain that suspension between the moving parts, if not you'll have journals and bearings making love and grenade a motor. Remember that all moving parts inside the motor aren't ball bearing and are journal bearings and require oil to separate the surfaces from contacting.
    • Yeah I noticed this just now. No doubt she will be running smoother next start😂🤣😂
    • ENR34 manual transmission transfer cases are 33100-23U00 which is shared with all of the R32/R33 GT-Rs and GTS-4s. And the C34 Stagea. Do not bother with automatics, that is a huge effort to swap and the car will be worse for it. And an automatic transfer case does not have the right housing for the shifter which comes out the back of the transmission and goes through the transfer case. I already posted my response on reddit but if you didn't see it there here it is: You have almost certainly damaged the transfer case, the only question is how badly. Nobody can tell you how bad without more information. If you have a giant hole in the transfer case pissing out all the transfer case fluid then you need a new one. If it's not that bad then the only question is whether you burned up the clutches. Drain the transfer case oil and inspect for metal on the drain plug magnet. Small black filings are normal. Big chunks of metal or a ton of black fuzzies not so much. Fluid should be nice and red. Any other color isn't great. If the color is reasonably red and there's not a bunch of clutch material discoloring it or anything like that you probably got away with insubstantial excess wear not worth trying to fix. If you have to rebuild or replace the transfer case keep in mind you have to pull the transmission to get it off.
    • As promised………… the first start. Rough and a few bugs to work out. Still she lives att.1cnTUvrWxiOZUFbg0S43m1VFUdDhxGBq3UU53bvtkww.mp4
    • Can I suggest a 15W50 oil is too heavy. Its a brand new engine - you should be able to run something like a 10W30. Shove some steel wool into your catch can  - more technically "oil/air separator" - so that the oil vapour has something to condense on.
