Just made a cold air partition for the 'line, much better throtle response when the engine is warm, especially bottom end off boost - in fact, I cant notice much difference from when I start up to when I have been sitting in peak traffic for 1/2 hour. Well worth the effort.
The reason I was starting this thread is that I now have a template for a cold air partition (took about 1.5 - 2 hours till I was happy) and if anyone is interested to copy it, please let me know as the template is the hardest part. My template is designed around a FMIC, but it wouldn't be hard to modify for a stock one. I also have some metal backed foam left over - enough for one partition if anyone is interested, let me know, although the cost of the foam is very cheap, about $10 for half a lineal metre
https://www.sau.com.au/forums/topic/6586-cold-air-partition-template/
Mr Hyundai,
The partition sits just behind the pod and fits in where the suspension tower meets the inner guard, on the other side it goes around the outside of the little black emissions canister. I got the materials from clark rubber, just metal backed foam and I also got some 1.5 inch thick soft rubber tubing used as a heat shield for pipes, slit it down the middle and slot it across the top of the partition to seal with the bonnet. Not sure what the tubing's real name is but at work I have heard it reffered to as armourflex. It must seal pretty well as the induction noise from the pod is reduced a fair bit, but it still growls when you poke the loud pedal:D
Adam33, sorry dude, I'm not much of a 'tech drawer', but I might copy it onto paper and post it to you if you want. Youll just need to trace it onto card first (to check it fits and maybe modify) before cutting. If you dont want/cant catch up to copy it, just drop me your details at [email protected]
hi Steve,
Mate where do you live.
I wanted to know what kind of filter you are running at the moment. I downloaded another template recently and when i looked at the cut out i did on the car it was too close to the guard and the filter didnt even reach that far, so the box would have started after the filter finished, leaving the filter in the engine bay with nice hot air and the box in the corner, it was classic.
if you are near me I can rock around with some cardboard and trace the template onto it and then leave.
what you up to on the weekend etc. or have you already got a cardboard template
elaborate tell tell, actually maybe a few of us could meet up quickly with black texters and make copies. how does everyone feel about that.
laters
laters
thats a good idea, i wouldn't mind a copy either, i have got one now but it came with the car and isn't a very good fit, i think it would let alot of hot hair in.
Cam
I live in Willetton, the pod is a K&N. If you want to call around is cool, just drop me an e-mail or better still a pm, and I will reply with an address and phone number.
Unfortunately I will not be going to the cruise although I wish I was.
Anyone who wants a copy is most welcome
  • 2 months later...
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
    • You need to buy a Saab Matt, ours had a button that turned all the dash lights off. Any decent aftermarket dash has sufficient brightness control and a headlight input for day/night settings. None of which probably helps OP
    • Yeah thanks...i thought it would be alot more i dont know 😄 I saw some videos on converting push/pull and it seems you need to "drill" the hole for slave(master) cylinder and buy some converter kit. On that front yoke clip i did not even know that is a thing and i need to source that(custom shops do not do that?) But anyway thank you for the info
    • Not the headlight. It's the DRL that serves double duty as white and amber. Would be the easiest way to make it happen, if fitting a BCM was in any way an easy thing. Otherwise you'd do it with some relay logic and/or maybe some diodes.
    • Would require a very smart body control module which these cars are about 20 years to old to have
