Ok, I cant have a worse week,
My Car was Stolen from Ermington Shops at around 10:20pm Last Night.
From the woolworths shopping centre car park.
I was only in the shops for around 20 mins came back and it was gone.
I have reported it to the cops but if you see anything please let me know.
Craig
0410 635 901
0422 225 530
[email protected]
[email protected]
[email protected]
Please tell me she will be ok/..... :) :):(:):(:):( :(:( :(:( :(:( :(:( :(:( :(:( :(:( :(
Piks as follows
https://www.sau.com.au/forums/topic/65862-stolen-black-r33-eav-00l/
  • Replies 49
Mind me asking what alarms/etc it had?
20 Min is pretty quick (in the sense of it wasn't planned), ie they just happened to be waiting at the shops and jumped on it the second u were out of sight? Though if they were waiting for the chance, perhaps they had a towtruck a few min away?
me thinks tow truck of some sort was used, unless you were followed from where ever you were driving from. thats why i never take my car anywhere if i have to get out of my car. good luck anyways with finding it, that other stolen gtr was found, i hope you find yours too champ
i was in the middle of fixing the damage Litterally, i had just put the poxy for the fibreglass bonnet on.
I have a alarm and a 3 point auto arming imobilser, i have no idea how they got it, they must have been good.
If a tow truck was used then they would have been lightinging quick, i was only at the shops for max 30 mins.
:D im so disapointed, all that time and money.. gone down the drain.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
