OK guys, I see everyone else isn't having dramas fitting their head units! I'm more than capable of all the wiring but the dilema i'm having is when my car was imported, it had only the A/C control period! No brackets, no nothing so what I want to now is- - - How has everyone mounted their headunit? Is there a generic part that can be made to fit? Is everyone custom fabricating their mounts, etc?
I know for a fact that JustJap have the item you need as I saw one in a half cut down there last weekend. Give them a call: www.justjap.com im sure they can ship it to you if you arent local for a small fee.
I installed mine last week..
I got it right first go.. even tho all the colours of the wires were completely different to what info i could find : Only problem i had was i didnt ground it properly.. but that was easily fixed :D (stupid me) :P
One thing you will def need is the Nissan double diversity adaptor.. thats a must.. saves a whole lot of stuffing around!
The only plugs you need from the stock loom are these too here..
and wallah! you have a new stereo..
But if anyone needs any help just PM me.. i would be glad to help out anyone who has any problems :P
- Corinne
  • 1 month later...
I installed my own stereo from scratch, laying all new cables down the wells of the side of the car. I just need some stereo place to make me up a boot install now because all I have is an ugly load of cable and free roaming amps bolted to a bit of 12mm MDF.
I thought it was quite easy to install compared with my Laser TX3. Hardest part in the GTR was getting the power to the battery under the hood which involved taking the wheel off to get at the over sized grommet.
A MULTIMETER IS YOUR BEST FRIEND....when installing stereos :D
i guess that i need to re wire everything, could this this be done with ease or will it be better for a pro to do it?
Its fairly simple if you have some sort of idea that you are doing..
If you arent that confident maybe get a friend who has done it before or just get a pro to do it..
I didnt rewire mine.. and you can see what a mess it was.. but i cleaned it all up.. you just tape up what you dont need..
And you dont always need a multimeter! :)
Car stereo is car stereo, once youve done one they are all easy, ive done a complete install, front and rear speakers, boot install, and had numerous headunits in there without one hitch, multimeter makes life much eaiser, fresh wires never hurt and alot of custom work goes down well.
Ed
  • 1 month later...
Im amazed that no on has mentioned you may need to do an amp bypass. It may have already been done or it may not have a factory amp. To check, its a small round thing in the boot, screwed to the underside of the parcel tray
Sorry to dig up an old thread, figured it's better than posting a whole new topic.
Today I just put in a new headunit, very simple process, but I didn't have enough cabling for my speakers so I decided to just wire them up to the stock speaker wires. The problem now is I don't know if I have the stock amp you mention of. Is it actually round or is it more of a box with wires going in and out of it?
If it is can anyone give me any tips on how to bypass this, ie. a wiremap of the amp so I can just join the input to output?
Thanks guys ;)
BTW: Thanks to everyone who posted here, very helpful!
Edited by ToF
Hi ToF, I found that the stock rear amp in my r32 is round, with one small bundle of wires exiting it. Mine has a little white sticker which says "Clarion" on it, but yours may have fallen off. It's probably about 5x7.5x7.5. I can take a picture of mine and post if you want.
I'm not really sure how to bypass it (my rears are after market Kenwoods which glow "Kenwood", but don't appear to be wired to the front), but I've been looking into replacing all 4 speakers recently ... until I found out the hole is only 6.5" in the back, and 6"x4" in the front. :(
  • 2 months later...
hey i just bought a pioneer with blue tooth ($600 + deck) but im having trouble finding the existing rear speaker wires if anyone can remember what colour the rear speaker wires were that would be a great help
this is kinda urgent coz im in the middle of installing it now and i wanna have it done sooon
Ok so i thought there may be a problem with the rears, so i decided to check them from the amp plug and they worked fine.. so why cant i get them to work from the front plug???
For the front speakers the colours look to be the same on the front plug as the amp (however couldnt get them to work from the amp plug for some reason)
For the rear speakers the colours on the front plug are different to the colours on the amp..
help someone What colours are used the rear speakers on the front plug??????
i have tried trial and error but couldnt come up with the goods
Are you using the 'pre-94' harness wiring from that PDF? I have followe that for my brother's 1989 R32 GTST (amped setup) and it all matched up.
Haven't had any complaints re: the wiring guide so I guess double check your connections again.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
