Wonder if anyone has had this problem.
When my R33 warms up it starts to make a rattle from somewhere near the drivers side wheel arch.
The sound comes when you give it a bit of stick and then back of or when you are sitting idling. Give it a small rev and it goes away until idling again. Anyone had this before.
Noise started after 1500 Km trip to Kalbarri on rough roads at high speed :flamed:
https://www.sau.com.au/forums/topic/65920-rattle-when-idling/
Does it sound like an engine rattle or more so from somewhere on the frame/body. Check bodykit mounting points, check indicators are still screwed in properly, check headlights. Rev it from the engine bay. You should be able to get an accurate location this way.
Hi,
I dont know too much but just thought this could be of help.
If the problem is not panels or bodykits, could be idler bearing... I had an exact problem with another car (not my skyline). So if your car has done close to 100K and the timing belt etc has not been changed, take this into account.
Steve
Clutch doesn't change it, removed and re-seated headlights, checked struts and suspension, even tightened all the bolts and nuts in the vicinity, and relined the brakes. No loose panels and the body kit is all firm and intact. Just can't work out where the rattle is coming from.
From the inside of the car it sounds like it comes from near the wheelarch. From the engine bay can hardly hear it. Might be one of those pull everything apart on the long weekend jobs. :headspin:
Try this. Stand at the front of the car with the bonnet closed and see if you can hear it. Then open the bonnet and stand at the front of the car. Is the noise still as loud or does it change?.
With the bonnet closed - push down on the side of it to see if the noise changes note or volume. Try bouncing on the suspension to see if it changes.
Long shot but get your exhaust checked. Sometimes noises can be very deceptive as to their location. It is very likely that the noise could be on the opposite side of the car but it sounds like it's coming from the driver's side.
So is the noise definately louder from inside the car than out or is it just louder inside than out when the bonnet is up. (if you know what I mean :) ) ?
    • Followed ☺️ Assuming those are NEO rods, then at least 400kW all day.
    • Lets keep this going , Spotted this very stock V35 in Penrith and also saw a nice R32 FLY past me on Castlereagh rd , sounded really good.
    • Great work! Give it a clean up with some Emery paper, and I'd run a thread die over the threads too to clean them up. It will make reinstall much easier, and also life easier for the next time it needs to come out.
    • I'm not a fan of high humidity, it's one reason I don't mind being further inland out Ipswich, except the last 3 odd years, the drought broke, and it won't stop raining, which is making the humidity nearly unbearable when the rains are in during summer! For me, my body hates the cold, once the cold sets into my body, I'm totally screwed. I end up with severe muscle spasm in my back/shoulder muscles, and it feels like someone is trying to tear the muscles out. I have no issues with it getting stupid hot, so long as the humidity goes away. So the last 3 years as above, have been woeful! Ha ha. However, June 1st, and I'm only just converting from shorts and a tee, to long pants and a t shirt. And that's mainly as it's a bit wet and miserable and I wanted to work on a car.
    • I much prefer colder weather to hot weather, and especially prefer cold to hot and humid, Goulburn does gets pretty warm in the hotter months, but, I've found the humidity there is not as painful as even Sydney, the humidity up north is to oppressing for this old rooster  In saying this, it does get rather "nippy" in Goulburn for early morning, late in the evening walks, but nothing that a layer or two, some thermal gloves, and a beanie doesn't fix to make it an enjoyable experience, which is much more bearable to me than the oppression of heat and humidity,  especially at night when your trying to sleep If I recall correctly, a "wise man" once said that the "Southern Tablelands" was gods country, and I will not argue that point with him for the fear of a "permaban" LOL In car part related news: My intake is currently in Botany getting processed for the last leg of its shipping journey to my door
