Well, I been lurking around these forums for a few days picking up bits of useful info here and there so I thought I should do the neighbourly thing and introduce myself...
I'm from Brissy and I just bought a silver 96 R33 series II GTST. Still getting a few things sorted on the car, bit by bit as money rolls in, and the wealth of information on these forums have been invaluable! Just shows what a community can achieve helping each other eh?
Well I'll be around here for a while I reckon so cheers to you all and hopefully see you on a cruise sometime soon! :(
https://www.sau.com.au/forums/topic/65924-hi-to-everybody/
G'day mate,
Welcome to the forum. You didn't happen to buy your car from Sunnybank did you. I looked at a 96 Series 2 from there before I bought mine, and it seemed a bit dodgy. The paint looked like a bit of a dodgy respray, and for a car with so few km's, it certainly was pretty rattly / loose feeling. Anyway hopefully you got it checked out first if it was the one I am thinking of.
See you around the place. Go the silver 'lines.
Brendon.
Welcome :)
https://www.sau.com.au/forums/topic/65924-hi-to-everybody/#findComment-1230839
I might take some pics tomorrow, got a couple that the guy I bought it off took but I had to remove a few stickers...looks cleaner and classier now :D
I didn't get it from sunnybank, got it up at caloundra. It's had a bit of respray but hasn't had any major prangs (according to the guys that checked the bodywork and stuff). I think a lot of these cars get resprays either before leaving japan or getting here, just fixing up dings and stuff I guess.
I did get a bunch of useful info, esp. about removing interior panels to get a new stereo in (should be in tomorrow, listening to the engine is nice and all but it feels lonely cruising around alone with no tunes :cheers: )
I'm usually cruising around auchenflower/toowong/milton/UQ area as that's where I live and play a lot....rego is 264HVI if you see me around say "hi"
I've only had the car two days...man I'm so in love...I'd sleep in the garage if my girlfriend would let me. I said this to her on the first night...she thought I was kidding lol.
https://www.sau.com.au/forums/topic/65924-hi-to-everybody/#findComment-1231765
My girlfriend got the 5hits up coz I told her she would always come second to the skyline. That, coupled with the fact that I have been going out with the skyline for 2 years and her for 3.5 years.
I am bad. I didn't mean it though. She thinks I did.
https://www.sau.com.au/forums/topic/65924-hi-to-everybody/#findComment-1231771
Yes that will get you in trouble...thats why I am secretly going out with my car...shhh don' tell the missus...or this may happen :kick:
https://www.sau.com.au/forums/topic/65924-hi-to-everybody/#findComment-1231954
G'day mate' date='
Welcome to the forum. You didn't happen to buy your car from Sunnybank did you. I looked at a 96 Series 2 from there before I bought mine, and it seemed a bit dodgy. The paint looked like a bit of a dodgy respray, and for a car with so few km's, it certainly was pretty rattly / loose feeling.QUOTE']
Was that through a private sale? Cause my friend and i went to look at one in sunnybank that the guy was asking $20,000 for, completely stock. It looked very dodgy though.
https://www.sau.com.au/forums/topic/65924-hi-to-everybody/#findComment-1232646
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
