A friend of mine has just got his VC Commie tuned and its pushing 480+HP at the wheels. He did an RB30 conversion and put that in and its twin turbo. It looks like an old commodore but it goes really nuts. I was thinking he might do high 10's once he has it all in line, that is one fast street car.
I will try get some pics for you guys or get him to post here.
https://www.sau.com.au/forums/topic/65966-holden-rulez-lol/
http://members.ii.net/~tfroggydawg/images/cars/
The pics are large so feel free to zoom.
He still needs to put his front bumper back on.
He is running Twin Garrett T25/40 ball bearing turbos.
There are also some pics of another friends SS torana with a RB25 in it... its not finished.
https://www.sau.com.au/forums/topic/65966-holden-rulez-lol/#findComment-1236797
sounds like a beast and a nice sleeper :)
if its manual, 10s will be a big call without smashing unijoints, and bending diff arms on slicks (i had trouble with both on only 350rwhp in the vl)
i think auto would easily get 10s and sure does save that driveline :P
i gave up with the commodore cause i was told only way to upgrade uni joints was a ford 9' diff and then i need a tremec 6 speed which is about 8K so i gave that a miss :(
4wd is the go :D
but must admit ill be missing the crazy sideways action of the vl :aroused:
good luck to the owner and hope to see it on some cruises :)
cya guys
Brad
https://www.sau.com.au/forums/topic/65966-holden-rulez-lol/#findComment-1237976
480HP at the wheels in a Holden chasis, i couldnt see that getting anywhere in the 10s unless he puts some of the money to some serious suspension and drive train work.
but least he's realised what power you can get from nissan.
Thats prolly the dumbest thing ive heard. It has a nine inch diff with a mini spool and a live rear end. What do u think all the super street cars run at the drags ? Let me give you a clue its not nissan IRS thats ripping out 1.5 1.6 60ft times.
https://www.sau.com.au/forums/topic/65966-holden-rulez-lol/#findComment-1238458
mates lh torana, totally stock susp with decent shocks, 9", 400rwhp, consistent 10.5's 1.5/6 60ft's on 8" slicks at the western nat's. jxl you have no idea
there is also an lj running around with a 26-a top bloke, but this vc looks insane
https://www.sau.com.au/forums/topic/65966-holden-rulez-lol/#findComment-1239924
there are trevs who think v8's are gods only way to go fast,
unfortunately,
there are also a newer breed of ppl who think imports are the only way to go, kinda like a trev, but with a japanese flavor, blame fast and furious for that.
there is more then one way to skin a cat, repsect it for what it is and watch out for it to rip out some awesome times.
https://www.sau.com.au/forums/topic/65966-holden-rulez-lol/#findComment-1240224
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
    • Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference!   halal food near me
