My dad (whos in the tyre world and called to try and get me a good price) gave them a call and they said they are waiting for the 1st shipment to come and would email me a price the next day, email didnt come.
Ash.
Though it may have been the size that i wanted as its 275/60/15.
https://www.sau.com.au/forums/topic/6607-nitto-tyres/#findComment-98831
I rang Croydon and they wanted $5k for a set to be brought in
I then rang Auto Concepts and although they don't bring them in yet, they plan to by Jan. Price is unconfirmed but I'm hoping it's gonna be a hellava lot less that what Croydon want for them.
I almost fell off my chair when I heard that considering I could get a set for just over $3k straight from the US myself.
https://www.sau.com.au/forums/topic/6607-nitto-tyres/#findComment-99286
I read on the "other forum" that in US quite a lot of guys use
Nittos on the street & get good mileage from them.Not sure on tyre pressures though.I just got a set of 275/40/17s.Not sure if I can get more though.PM if need help & I'll see what I can do.:burnout:
https://www.sau.com.au/forums/topic/6607-nitto-tyres/#findComment-99632
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
