Hi guys.... just wondering if any of you guys have had any problems with the 4WD system???
When ever I start my car the 4WD light will show up on the dash. The problem is that when I switch off my engine, I can hear this buzzing sound at the rear driver side quarter panel. Its not the fuel pump sound... sounds is related to the 4WD system. It will keep buzzing until it drains the battery totally flat.
I've checked the fuse for the 4WD - all ok. If I pull it out the car will just stall.
I am thinking this maybe an electrical problem.... any advice, any recommendation???
Or any fix to it, before i take it to an auto electrician or mechanic...
Help!
https://www.sau.com.au/forums/topic/6608-gtr-r32-4wd-problem/
Hi guys....
The problem is not with the battery, as I have replaced with a brand new one. Also replaced the alternator as well.
When I start my engine, the 4WD will come on, you will hear a buzzing noise from the rear of the car.... right above the diff.
It appears to be a controller module for the 4WD system.
I have taken out the fuse for the 4WD totally iliminating the 4WD driving system. Since then my battery hasn't gone flat, but I am left with just 2WD mode.....
Have any of you guys have this sorta problem before??? I am thinking it could be something small... something electrical... stuffed regulator or something....
Any recommendation of who should I bring it to????
HELP!!!!!
The buzzing noise at startup is the 4WD pump priming the 4WD system. If the pump keeps working, presumably the pressure sensor is kaput, because it is not getting the "alright, alright, enough pressure then" signal.
Thanks for the info... I think you are definately right though... thats what it sounds like.
Is this pressure sensor unit on located on top of the rear diff?
Any idea on where I can get this fix in the sydney area? And the likely cost of the unit.....
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
