Finally got around to getting my fmic installed (gtr r32 cooler on r33 sedan with usual mods, pod, exhaust, dump pipe)
Decided to go with a mob that did a custom plenum and throttle body with the fmic install (got a good price as i did some pc work for them) and liked teh sound of clearing some space above teh engine
got the car back and its running terribly (felt like a misfire bigtime hitting boost)
got it dynoed today and the tuner told me that basically the standard computer is having kittens all over the shop (injectors are maxing out, computer is throwing up fuel cut and going into limp mode when booting it in 3rd and 4th gear, sometimes second)
i was originally planning on going a power fc relatively soon after the install, but the tuner told me that it wont do teh job because of the mods to the plenum and throttle body and the associated sensors, is this the case?
hes told me i need to go a motec M400 (like 4grand worth)
do i have other options?
ive turned the boost right down and am basically just going to put around to not risk blowing up the engine;
yeah would like to see some pics of modded plenum.
What boost were you running when it was running ruff, but I wouldnt think a standard turbo would make the injectors max out anyway??? unless you were running huge boost but then you'd be picking the exhaust wheel out of your dump pipe.
I would be taking it to another turner anyway to get a second opinion anyway before you go buy a $1200 PFC or a $4000 motec
ok, got the car sorted (props to motsons in brissy)
somehow the first mob i went to, missed that the timing was way, way out (33 advance)
that the tps hadnt been reset/calibrated correctly and that the throttle cable was sticking
car back in tip top shape and awaiting engine managemnt
ill post some pix of the custom work as soon as i get the pix online for those that were interested
some pix of the custom plennum and throttle body for those that are interested
all i know is that the throttle body is off a ford (i think its a 5 litre ford throttle body . . .)
http://members.optusnet.com.au/davidbrough...hrottlebody.jpg
http://members.optusnet.com.au/davidbrough...erthehoodee.jpg
http://members.optusnet.com.au/davidbrough...hton/thecar.jpg
well, coz the dramas i had after the work (see above)
im just runnign around on 6psi atm (wife made me, she didnt want me breaking anything again);
that said it scoots along quite nicely
ill get my engine managment done soonish, so ill post a dyno then
