From your personal experience, what normally comes out on top? What's better in low-range and top-range? What pulls off the line better and what normally wins in the end?
I'm asking this because I am considering doing a RB20DET conversion in my auto ca18de because RB's are heaps cheaper than SR's.
https://www.sau.com.au/forums/topic/661-rb20det-vs-sr20det/
Here is a good comparison
My R32 gtst (rb20det manual)
fmic
3.5" turbo back exhaust
filter
cold air box
15 psi
vg30 turbo
s-afc
bigger fuel pump
My friends 180sx (sr20det manual)
fmic
3" turbo back exhaust
filter
13 psi
gtr fuel pump
Basically both cars are pretty much even up to 150km/h then the skyline gets about 2 car lengths on the 180 up to 220km/h
ALL TESTING WAS PERFORMED UNDER CONTROLLED CONDITIONS BY EXPERIENCED DRIVERS. IT IS NOT RECOMMENDED THAT THESE ACTS BE DUPLICATED ON OPEN ROADS. ALWAYS WEAR YOUR SEATBELT WHEN DRIVING AND HAVE A NICE DAY
https://www.sau.com.au/forums/topic/661-rb20det-vs-sr20det/#findComment-15326
hahahhaha *cough* bullshit *cough*
well think of this .. with the money u save on gettting the rb20det, u can get a new turbo or ecu or whatever u want.. then which will be quicker??
engines both have there good and bad points.. sr20det is an alloy block adn the rb20 is the cast iron... sr20det has a timing chain rather than a belt.. rb20det is a 6cyl thus more torque
both engines are bloody awesome.. but it always goes down to money in the end... :P
https://www.sau.com.au/forums/topic/661-rb20det-vs-sr20det/#findComment-15336
That's the big factor in all things I recon...bang for your buck... if you go the rb then you need a engineer cirt because you go from 4cyl to 6cyl......I have personally done this conversion so if you need any tips let me know.
I would probably go for the rb for the torque...
URMINE hows your heater going?
Cam
https://www.sau.com.au/forums/topic/661-rb20det-vs-sr20det/#findComment-15338
Thanks for all your help guys. On the High Performance Imports video Vol 3. (currently being borrowed by me off a friend ;) ), they show a S13 Silvia with a VG30DETT in it. Pretty PHAT I reckon!
And I'm not going to spend the money on my current ca because it is non-turbo. Spending 2k on my current engine, would that bring it up to scratch with a rb20det (serious question)? And I definantly won't be putting a rb25det into it because of the cost.
Also, boostmeister, what has to be fabricated/welded/altered to put the rb20 in the S13? I've heard that the heater hoses have to be altered and besides everything in the halfcut, you'll need a rb tailshaft and a bigger fuel pump in the tank. Is that it?
https://www.sau.com.au/forums/topic/661-rb20det-vs-sr20det/#findComment-15446
Guys stock for stock The Rb has less toque than the sr20det and will always be less torque. six 8 or ten cylinders dont matter as the stroke on the Rb20det is very very short. Good for revving but thats about it.
Rb25det is the way to go.
Sr20det has a timing chain and roller rocker arm style setup.
Alloy block is light but there is so much alloy there that it doesnt make a big difference.
Rb20det is a tough motor. But so is the sr20det.
I say different strokes for different folks. LOL
https://www.sau.com.au/forums/topic/661-rb20det-vs-sr20det/#findComment-15936
