Hey All,
Having troubles taking my stock R33 steering wheel and putting a new one on. I undo the cover from the stock steering use a hugeee rachet to undo the bolt in the middle but i can't? am I doing it right? you undo the middle bolt after taking the cover off to take the stock steering whee; right? :)
https://www.sau.com.au/forums/topic/66103-taking-steering-wheel-out/
I haven't done a r33 specifically, but there should be a big nut - around 22mm. They sometimes require a bit of persuasion. Once you have undun it, leave the nut on a few threads, otherwise you it comes time to pulling it off you will smack yourself in the face. Start by squirting some cats piss (WD40) on the spline and let it soak, then get your knees under the bottom side and push up and towards, and pull like a catholic school boy on the top.
When I flies off you will be glad that the nut on the bottom saved a dent in your forehead. :)
Cheers
Sumo
ร—
ร—
