Last night I was driving normally and then came up to a hill and said what the heck and felt like giving it a good thrash. Anyway I reved my car and dumped the clutch but a few secs after moving I was like wtf why isnt my wheels spinning and the cars moving. I tried to push in my clutch as I was coming to a stop sign and realised my clutch was all the way stuck at the bottom!! Only other time ive felt this is when my clutch cable snapped on my civic. I couldnt put my car into gear for bout 1 minute then it jst popped out and was normal again??? Only thing is my clutch feels a bit softer and i cooked it harddddd!! The clutch smelt all the way home and when my car was in the garage the smell was there for at least an hour.
Did i wear out my clutch alot just then? And why would the clutch stick to the floor????
https://www.sau.com.au/forums/topic/66122-weird-clutch-problem-info-plz/
with your pedal stuck to the ground, this sounds like a hydraulic problem (master cylinder or slave cylinder or both). Yes other cars use a cable clutch but skyline uses hydraulic.
To get your master cylinder reconditioned with new seals and stainless steel sleeve if needed is about 70-100 per cylinder. Mechanic can do this for you or you can give it a go yourself, i tried it myself and ended up stuffing up the master cylinder again so for $200 or so save the hassle and let a mechanic get it going for you.
With the clutch - any idea on the wear on it? is it new? old? due for replacement?
I had the same problem in my daily driver ( aus R31 ) about 3 months ago although I wasnt caining it. Just driving along and all of a sudden the pedal went to the floor.
Stuck my foot under it and popped it back up.
Never had a problem and it hasnt happened since.
yeah dude, i had same prob in r33 gtst. Went to do burnout with some mates in the car, revved, dumped clutch and car didn't move at all just revved like shit. Went to put clutch in and realised it was still stuck all the way down. Same thing, just popped out after a few secs and smelled like shit. Clutch then started taking heaps far out. That was a few months ago and i've been nice to it since. Still i think the clutch is gone and probably a hydraulic problem.
Let us know what yours turns out to be man
Cheers
He means the clutch wont engage or grab until the peddle is almost out at its furthest point.
Check your clutch fluid level.
I had the same problem in one of my Integras, it was the clutch master cylinder..
Yeah my friend had a similar problem with his DCR2, but his clutch has done 100,000+! so its due for replacement, anyways he couldn't put it into gear, then we got it checked,
the clutch fluid was low, they topped it up, no problem since and his still driving dunno how the hell the clutch is lasting so long for him, he drives CRAZY!
Kriminal this happened to me 2 nights ago. My car is still off the road and had my mechanic have a quick look at it at home (didnt jack up the car), he said possibly the clutch fork is bent broken or out of place, or maybe the pressure plate has collapsed
did something the same went to pop it and then found that I couldnt select gears (no clutch) waited for it to cool, no good, I had to drive home with no clutch so learnt to match rev quick. Found problem to be that pressure plate weled its self. Came unstuck with some help from 2nd gear
Yepo, this happened to me only 3 weeks ago..
Took car to mechanic, 2 things were wrong..
1) I had a tiny slit in the rubber connect hose from clutch cylinder to master cylinder pipe..that needed replacing $15....(situated under car, under drivers seat)
2)the actual steel pipe that holds the clutch fluid from master cylinder (under the hood) down along firewall to the slave cylinder, under the car was not in the master cylinder far enought therefore, air was getting in under pressure, therefore clutch went floppy...
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
