hi ppls, recently bought some small goodies for my s15 off ebay. the trader seems respectable with 1000+ feedback and 99.8% rating. anyways, they said they sent the item and was signed and received. However, I never have signed for anything and definatly have not receive anything. we confirmed the address is correct.
Iam waiting for the fax with proof of delivery and signature, but my questions is how can I verify with the seller that the courier made a mistake ??
I was thinking just faxing them back some legal document with my real signature, would that work ?
Loge a dispute with EBay IMMEDIATELY!!
http://pages.ebay.com.au/help/tp/inr-snad-process.html
Ask for details of a tracking/shipping number, and once you've got that contact the courier and seek written proof re: the validity of the number.
I'm currently trying to resolve a similar dispute with a seller in the US and it's a bit of a hassle. But the earlier you get in the more likely you'll get something.
Generally a trader on ebay with that much feedback is not going to rip you.
Most likely they sent your item and the courier company has stuffed up.
The best thing you can do, as previously advised, is to open an 'items not received dispute' through ebay, gather the couriers details and contact them yourself. I wouldnt bother faxing them your signature, it wouldnt help at this stage.
Just curious, were the items sent from overseas or within Australia?
first try and get the dudes phone number and call him and also get the name of carier and ask the dude for the numbers of the item and complain their. and then follow with making a official complaint on ebay or threaten with that and legal action and he will start to get picutre u are seriuos. their is a way u can get some money you will have to read up about it
blah blah, chase the bloke up
get the courier company's number and ref number..
trust me i no.. someone off ebay still owe me $1400 from october last year..
sould find my thread.. see if the seller is reluctant to give you the courier company and number then u'll get an idea if his full of shit or not
ye rang the seller and got the tracking number and run sheet for the day. called the courier company and found they sent to the wrong address! they misread the label the dumbasses. they say they will retrive the item and get it back to me....
what pisses me off is the person that got the package wasnt honest enough to say he wasnt expecting anything and just took the package.
if i find its being opened and tampered with i'll be pissed.
hell yeah- do something about it. it wasnt the sellers fault so dont give negative feedback. ive had that problem, goods arriving smashed due to poor packing. or damage not said in description. thats the thing about ebay, its not just and auction. its a gamble. but its good fun too. got to be real careful though.
Hi.
If the package has been opened and kept, report the recipient to Police, as they have committed theft. A person is obligated to make all efforts to return found / received items if there is a reasonable chance of the correct owner being identified.
Good luck.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
