Gday,
I know alarms have been covered in threads here but none seem to be installing alarms themselves.
My question is this-
I need an alarm that I can install myself (so sold to public) that is black wiring and remote keyless ... As well as having all the code hopping stuff and ability to be silent (I hate when the car beeps as you open/close it).
It should also have 3 immobiliser points minimum and it would be nice to have additional inputs/outputs (so it can accomodate boot, doors, bonnet, tilt and microwave/proximity.
The jaycar ones look good but unforunately (and stupidly in my opinion) the one with all black wiring doesn't have remote keyless entry (shadow), and the one with keyless entry (and all the features I want) doesn't have black wiring (car steel, steel mate or something..) Go figure.
Anyways - any help is appreciated - if installers can sell me a kit that'd be good too - but I spose people don't sell these things so the wiring diagrams don't get out.... although with black wiring I don't see how it matters.
Thanks.
https://www.sau.com.au/forums/topic/66143-diy-alarms/
Check Ebay if you can mate, there are some nice alarms on there. You can get the ISO approved Australian ones like Cyclops, Black Widow or if you want to save some money you can get cheaper ones.
I bought a 'cheap' Chinese unit for $50AUD delivered, and it was great. Central locking output, silent arm/disarm, immobilization, shock sensing, 100db horn, was a very good unit. (Apart from the Engrish installation manual)
give it a try!
Blacky.
https://www.sau.com.au/forums/topic/66143-diy-alarms/#findComment-1234334
hi mate, I bought mine through Autobarn! only cost me bout $200 and it has just about everything you listed above (no microwave sensor). very easy to install.
I did mine, as I have seen some slap happy wiring jobs (no-one takes more care with yor car than yourself!) and I didn't want anyone else to know where and how it is wired up :)
https://www.sau.com.au/forums/topic/66143-diy-alarms/#findComment-1234633
For anyone else looking at this thread I just noticed the "BW10000" look dodgey as.
Considering -
a. google seems to be spammed with the item pointing to ebay
b. BW homepage doesn't have this model at all
c. the seller's feedbacks looks 'strange'
Anyways, I'll keep looking :)
https://www.sau.com.au/forums/topic/66143-diy-alarms/#findComment-1238657
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
