Hey Guys,
My car is for sale again. It has to go because I just started university plus I work two jobs. I can’t help my self but always wanting to spend money on my car as well as wanting to save a deposit for a house. So, I have to sacrifice the car unfortunately. The car is a 200sx S15 Spec S Australian Delivered Model. Its built in July 2002 and has done less than 32,000kms and is of course MANUAL and PWETER in color. It’s garaged 7 days a week and is in AMAZING condition both inside and out. I always warm the car up before I go and is always warmed done via a turbo timer. The car is basically stock standard apart from a:
• Apexi Pod Filter Kit for S15 plus Heat Shields
• Pivot Boost Gauge (lights up blue at night)
• Greddy Turbo timer (shows speed, voltage, 0-100 times etc).
• Sunroof (came with car)
I have all log books and is serviced every 5,000kms at Horse Power Factory (Amberley Autos).
I may be interested in a swap (180sx or other) PLUS a cash adjustment of at least $15k. If not a swap, I’m asking for:
$32,850 (relatively firm)
Please PM for more info or call me on 0421 847 981
No time wasters please as im really busy with Uni back on and work.
MELBOUNRE BUYERS ONLY!
Cheers,
Rob.
https://www.sau.com.au/forums/topic/66154-fs-s15-stock-in-amazing-condition/
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
