Hi all,
Recently I installed a FMIC on my R33 and am noticing a boost creep at mid - hight RPM (4500 +). The bleed valve is set @10psi, but it continues to creep up to about 13psi before the redline, with no power gain after 10psi.
Also like one of the previous posts the flutter noise on the BOV (turbosmart) has slowed down quite a bit and goes off on like 5vac on the boost gauge and under 2000rpm.
Have checked all plumbing several times but no difference. Please help as its confusing the hell out of me....
Ta
Marcus
So boost creep with bigger FMIC is normal then? I have a turbosmart bleed valve.
One thing I forgot to add to my original post was that ever since the installation, on cruise @ low rpm, regardless of which gear, the car sort of jolts (like has hickups) however under acceleration its fine. The only other thing done to the car at the same time was a 5" cold air intake to the pod. But I can't see how that would cause any problems... Any Ideas, anyone???
  • 1 year later...
Sorry to resurrect an old thread, but i have a question regarding manual boost controllers etc. My car has a pod, fmic, zorst etc, stock ecu all the usual bells and whistles. :(
however, i have disconnected the standard solenoid, i.e running vac line straight from fmic piping to wategate actuator yet my boost still slowly creeps up till redline. the car runs 6psi till about 4500 then as if it had the dual stage connected it slowly increases with the rpm to 10psi by redline. :woot: My question is, if i install a bleeder / ball spring boost tee, will it enable me to increase the boost earlier on, as in reach 10psi quicker rather than it slowly increasing to it by redline? Or will it make both levels of boost increase, i.e if i make what was 6psi go to 10psi, will my 10psi go to 14psi?
thanks
Edited by R33silverS2
Sounds like you did it wrong. 5psi to 4500 - 5000 is normal then the solenoid opens and you get more boost.
Sounds like but i don't think so, like i said the solenoid is totally disconnected, the line runs from the fmic piping to the actuator, the hose from the solenoid that used to be tee'd into this line has just been blocked off also. buggered if i know. still anyone know if a manual boost controller will give a net increase i.e increase all boost levels by a ceratain amount, or will it enable me to bring the earlier level up to 10psi and then hold 10??
thanks, but the thing is i dont have a bleed valve atm, it is just running standard and reaching 10psi, my issue is that it reaches 10 psi just before redline, so basically what i would like to know is would a bleeder of some description enable me to reach full boost (10psi) earlier in the rev range?
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
    • There’s probably people who’d like to do it and then when it comes to putting their hands in their pockets they’ll all disappear into the shadows
    • interesting....sounds like the later trans has software differences (or AM vs JDM). If I wasn't going down the tuning route it would be worth looking into retrofitting a new computer to the old box.
