  • Replies 288
Hey mate.
Just curious as to why you say the High Flow's are only 300hp when GCG and a few other places all quote there turbos at 450hp?
Just did a bit of a serch and a lot of people are getting 230-250rwkw's out of there high flows... Sydney Kid being the exception with 264kw
Also Does it matter if I get a R32 turbo highflowed instead of a R33 one (if cost is a huge difference between the two)?
as I will be buying a 2nd hand turbo and getting that done so I can bolt it on when I have all of my parts ready to go.
I am looking to upgrade the turbo in the next month or so. Just waiting on the bank balance to rise just a touch more.
Thanks mate
Yes, the highflows are only rated at around that figure. And like I said previously, it doesn't mean you can't get 250 rwkw out of your engine with that turbo on. It just means that the turbo is working overtime and is not built to withstand punishment to that degree. Those turbos are capable of handling those horsepower figures but for how long? If you fit things like oil coolers and use a 360 degree thrust bearing, then you will have no trouble supporting 250 rwkw and still have a reliable turbo.
Another example.
Get yourself a 1000hp Skyline and bolt on a highflow turbo. Give it a couple of laps around Philip island and I bet there won't be much left of it. It will also reduce the performance of the engine somewhat.
It is all about getting the turbo that matches your engine and mods.
The other thing I forgot to mention was that I was getting almost 220 rwkw out of my RB20 highflow on standard injectors and standard ECU. That was pretty much the max for it though as injectors limit the horsepower.
So like I said before, you can still get the 250 rwkw but you can't gaurantee the life of the turbo. Plus for the extra $500 you would be mad not to put on something better suited and put out 300 rwkw
How much horsepower/kilowatts do you want? 230rwkw
What are you using the car for? eg. Street/drag
When do you want boost roughly? coming on from 2200...full @ 4000
Do you want power early or late in the rev range? mid-late - i dont mind a Little lag if if will give a better top end hit...must last to redline
What Mods you engine has or is going to have including computers or exhaust etc.? zorst, intake, FMIC, fuelpump, injectors, probably a power fc, possibly cams
Obviously, what car? S13 with a RB20DET
Intercooled? and is it large, small, medium? medium at his stage....VR4 cooler - apprantly flows enough for 230rwkw
Still running AFM or upgraded or no longer there? stock Rb20 80mm AFM
Custom exhaust manifold or standard? (custom exhaust manifolds give you more options) stock manifold - as below....preffered stock but non stock if price is right
External wastegate or internal(limited to virtually 450hp - internal gate preferred but external if price is right
thx jason :rofl:
Mate, if you only want 230 rwkw. I should be able to get you something for around $1700 that will come on full boost at 3000rpm and last way past redline.
General rule is....if your engine stops producing power, so will the turbo. Or even if the engine reduces in power, so will the turbo.
You would probably be best to go for something like a GT25/30. you would be best to wait until they come out with the T3 flange configuration as this will mean a couple of hundred less in fitting costs.
well i think i'll definately want 1x GT35r with the .82 housing so thats $1900 ??
and i may also want a 1.06 exhaust housing for the GT35r (my current one has .82) $ ??
if you want you can PM me more details or a contact number :D
Cheers
Dave
The 2530 on the RB20 is actually quite a nice combo.
Its all in by 4000rpm and makes really good power.
On the RB25 I think its a little small, especially when you consider they only make 220-230rwkw max. The stock turbo makes 190rwkw or with an adj. cam gear maybe 200 depending on the dyno.
Bare minimum on the rb25 I would go the 2535. 240rwkw is fairly decent for the outlay.
Comparing the rb20 to a 25 is like comparing a dyno graph of a 25 to a 30. :D
You are right, the 25/35 would be a better match with that engine.
Cheers
Dave
I will be speaking to him tomorrow (Friday)
$1900 is correct for the Garrett GT35R.
He is getting back to me about the exhaust housing.
On another seperate matter. The T04's that I was talking about earlier for someone, he will be giving me an answer tomorrow also. He has been away in Perth for a few days so I haven't been able to contact him.
I have a contact who owns a very reputable TURBO business. They took over from Turbotorque around 3-4 months ago. I am getting VERY good prices for ALL turbos. I can pretty much get anything you want and to suit whatever. Prices are usually discounted by around $500 from retail so there are some massive savings to be had. Please post if anyone is interested.
EG. I just bought me 450hp Ball bearing turbo for a little over $1000. Retail on this particular one is over $2000 so you get the picture.
If there is enough of an interest I will see if he will give further discount for a group buy, however, a group buy is not essential. Sau members will receive further discount on top. These prices are NOT fitted. This will only put the turbo in your hand, or trailer - depending on how large you go.
where bouts u located.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
