Yeah, im mistaken.  GTRS is for SR engines so at this stage, if i can get the details for the garrett equivalent for the HKSGT2835 Pro S (0.68 A/R)
3LITE FORC3 - What's your price for the garrett equivalent for HKS 2835 Pro-S? (inc. oil lines, etc.)
  • Replies 288
OK, 1 x Garrett GT30R 0.82 Ex A/R Rated at 600hp has now arrived. Stuffs me why the others aren't in yet but I am still waiting. GT25/35's are on the shelf. So are GT25's rated at 350 and 400 hp. A whole range of T3 flanged turbos are to be released soon which I am also keen to see.
Answering the question above, The HKS GT28/35 Pro-S is a GT28 Turbine with a GT35 Compressor (52 trim). I'll find out tomorrow what code and price. None of these turbos come with oil and water lines. If you want oil and water lines....buy a HKS. I can't buy the kits seperate. You are only looking at around $200 to get braided lines made up anyway. As long as the manifold flange is the same style.
Daniel,
I need a turbo with 0.70 compressor and 0.82 turbine, internally wastegated, rated at around 700hp.
I was looking at the GT35/40R but I think it only comes in a 1.06 turbine internally gated.
Car is the R33GTST hiflow injectors, intercooler, fuel pressure regulator, Z32 airflow meter, Power FC etc.
Currently have a Hiflow but can only get 302hp aiming for 400+hp at the wheels
Cheers Dave
Answering the question above, The HKS GT28/35 Pro-S is a GT28 Turbine with a GT35 Compressor (52 trim). I'll find out tomorrow what code and price. None of these turbos come with oil and water lines. As long as the manifold flange is the same style.
Thanks.. post the price here when you have the details.
:D
Daniel,
 Cheers Dave
I am yet to see a turbo that is rated at 700hp that is internally wastegated. They don't have wastegates big enough and even if you could get one made, you would suffer boost creep something major. The fact is...if you want a turbo rated at 700 hp...you need to have external gate. I can probably get something made in internal gate but it will be totally useless.
The GT35/40R 0.70 / 1.06 int wastegated is rated at 700hp according to the Garret catalog.
Can you source best price for external waste ates?? Whats the best turbo with 0.70 compressor / 0.82 turbine? Has to be rated at least 700hp to get the 400hp at the wheels!
Yes, I can get a T04B but I'll have to check on a price for you tomorrow.
No I can't get highmount manifolds or external wastegates...well I can but for not much cheaper than you can. Normal trade discount for things like that. Talk to Slide if you want manifolds or wastegates or visit his website.
How much horsepower/kilowatts do you want? eg. 380rwhp/280rwkw
What are you using the car for? eg. 80% street 20% Drag
When do you want boost roughly? around 1 bar at 3800rpm
Do you want power early or late in the rev? range nice low down, but strong midrange and top end
What Mods you engine has or is going to have including computers or exhaust? 3 " exhaust G-Reddy Computer, 600x300x80 Cooler, Cam Gears, AVCR, fuel pump, injectors, malpassi, all the usuals
Obviously, what car? Toyota Chaser with a 1jz-gte
Still running AFM or upgraded or no longer there? never had one
Custom exhaust manifold or standard?Custom Exhaust Manifold
External wastegate or internal? External
I was thinking a 600hp GT30 with a .82 rear housing from what people and info i have read tell me. What you reckon and what price
Just a question about the 2530...
what flange do they normally come with ? cos i heard they normally come with T2 but sometimes come with T3. Anyway i assume these come with T2 so i just have to buy an adapter kit to make it T3 is that correct ?
any ideas where i can get just the kit, cos your price for the 2530 (I know you still have to confirm) is really good but i have no idea how much a kit costs
I'd reckon you are spot on. Prices for them change almost daily depending on how many he is buying but $1900-$2000 for the GT30R with 0.82 A/R. BTW good choice. They have one on the shelf ready to go I believe.
Yes that is correct. The 2530 is a T2 foot but I think you are still able to get it in a T3. I will see if I can find out tomorrow for you. If not, you would need an adapter plate made to suit it or get a custom manifold. The adapter plate a fairly easy to do but you would have to supply the manifold so that I can have it done for you. I don't know exactly how much it would cost but I can find out.
:P
Still waiting for the price....
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
