  • Replies 288
I might be interested later this year, if this offer still exists then. Haven't done any research into turbos though yet. I'd be looking at something good for a R34 GTT Auto. Something thats a good streetable turbo IE don't have to wait till 5000rpm till it makes good boost. Maybe even hiflo stock GTT turbo, not sure how this responds compared to stock 32/33 turbos but they are larger apparently.
You don't need to do any research.
These are the questions I need answered:
How much horsepower/kilowatts do you want? eg. 300rwhp/210rwkw or engine hp/kw
What are you using the car for? eg. Street/Drag or just Street or just Drag
When do you want boost roughly? eg. 2200/2500 or 2500/3000 or later
Do you want power early or late in the rev range?
What Mods you engine has or is going to have including computers or exhaust etc.?
Obviously, what car?
Intercooled? and is it large, small, medium?
Still running AFM or upgraded or no longer there?
Custom exhaust manifold or standard? (custom exhaust manifolds give you more options)
External wastegate or internal(limited to virtually 450hp)?
With this information I can give you a range of turbo's or just one that will suit your requirements. The more picky you are, the less range. eg:
if you want big horsepower: 5 or 6 decent turbos will suit
if you want big horsepower but want it smooth delivery at 3000rpm then it narrows it down to probably only one. There is a turbo to suit every request and any turbo can be modified to suit your needs.
So you give me info, I'll tell you what turbo/turbos will suit and you can do some homework on what I have given you and decide what you want.
How does that sound?
Answers:
RWKW? Enough to have a bit of fun on occasional track days.
90% street use
Boost @ 2500 rpm on but not dying above 6k
Early or late in range.. best average power from 2500 up
Stock standard R34GTT auto.
Thats why I said later on cos I'll need time to put on Full zorst, FMIC, EBC,
Fuel pump etc.
Internally gated sounds fine for what I want.
I expect <=250rwkw to be plenty for me.
Main issues for me are reliability and streetability/response.
Answers:
90% street use
Fuel pump etc.
You will probably be looking for something like what I am getting.
rated at 450hp, ball bearing. Easily capable of handling 300rwkw. Plus boost will come on full at around 2200-2600 depending on what level you wanna run. But should be able to get around 16psi at 2300rpm. And it will hold it through 9000rpm. Would cost you around $1700
i will answer questions for him as best i can:
As much HP for a tiny budget - doesn't have to be real crazy
Street use mainly
Boost aroun 2500-3k
Power Early in revs
blitz FMIC/3" exhaust, POD, boost controller
R33 series 1
Big BLITZ FMIC
Stock ECU/AFM setup
Custom dumps - 3" cat back
Main thing right now is he wants one that is almost exactly the same as stock 33 one - so just bolt on, attach current lines and away he drives..
No real budget right now - get me some prices on cheaper ones and expensive ones too - around the 1k mark
Not after massive power figures - just bigger than stock :D
Something to handle 450hp would be the same as above mentioned. $1700.
It doesn't really have a model number as such. It does but it is a custom made job by Garrett themselves. They make them to order.
If he just wants to hi-flow his one it will probably still set him back around $1300 depending on how bad he has damaged it.
All of these turbo's will bolt straight up to 33 manifold.
As I said before. The above mentioned turbo is a Garrett GT450hp ball bearing turbo. I can probably get something slightly smaller for around $1600 but they don't get much cheaper than that. Especially for BRAND NEW.
G'day Daniel,
I'm looking for a twin setup for my R33 GTR, along the lines or equivalent to 2530's.
What turbo's would you advise and how much?
The car is fairly stock, cat back, pods, and about to insatall a Power FC.
Then you will need the Garrett GT2530 twins rated at 500hp. As I said in the pm, they are available at 600hp and 700hp ratings also but this would not work effectively on yours.
    • I do have their “Nissanie Motorsports Co.” vin plates, but I am curious if anyone would have more info on them. Like how many cars they’ve imported and whatnot
    • Been a long while since i have updated this money pit lol.  Have had a few tune related issues with the car, first blowing the frost plug out the back of the head and then blowing the headgasket 3 months later, which has now been retuned and sorted. Done a few little changes along the way as well, i wasn't happy with the wheel and brake setup, so start of last year i managed to get myself a set of r35 brakes and nismo lmgt4 18x10.5 +15 Upgraded to now running a Precision Gen 2 6870 with a 1.15ar, to be honest felt more like a downgrade as the car feels much lazier around town compared to the Gen2 6466 previously. 0761719E-5683-43F7-BD3B-4BD94335DFF4.mov
    • Hi there, i am currently using the Elmers Racing Billet merge collector, we are using sch40 tubing and 1.5" ID, no cracks so far. however if i was to do it again, i would go sch10 with 1.25" runners
    • I haven't touched the turbos so might need to look at that 👍 Appreciated 🙏
    • If you haven't replaced the OEM turbos, replace them sooner than later. I have seen recent pictures of what OEM ceramic turbo failure can do in an RB26 and it will make a 10k AUD budget look like a joke. Single vs twins have been done to death on this forum. If your turbos haven't fallen apart you can probably send yours off to Hypergear for rebuild. The journal bearing option will have more turbo lag but it's a good bit cheaper. I would probably go for ball bearing CHRA but keep in mind ball bearing turbos are more particular about oil pressure/flow.
