no longer need those parts.so happy to sell them out.
Brand new WORKS 18x10 5 spoke deep dish wheel (wheel only) $3500
Used but in good condition Impul NS-GT 18x9.5 18off set 5 spoke wheel with RE-01 90% tyres.vgc $3600.forged wheel
used Equip 5 spoke wheel deep dish.18x10 11 offset .275/35/18 tyres 60%. $2700
Pair of GTR33 std turbo $1100
STD GTR manifold $200
brand new GTR after market Manifold $900
Trust 600x300x125 large intercooler $1950
os Giken twin plat clutch (push type with lighten flywheel) $1700
brand new Nismo 400R style Side skirt.from japan $850
Near new Zeal coil over suspension for GTR33 $1700
GTR STD G'BOX VGC $1050
https://www.sau.com.au/forums/topic/66217-a-lot-of-gtr-stuff-to-clean-out/
Can you post some pics. :)
details please?
its custom made for low mount turbo.std replace turbo.never been use.was made for my GTR with low mount HKS GT2530 turbo.but i change my set up to big single.so no longer need.
will try to get some pics.
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
