In NSW these days you can get up to 650cc on your L's/P's, depending on the power to weight ratio. CBR's and other sporty bikes are hard to learn on, and its even difficult to complete the P's test at the RTA as they don't have that great a turning circle.
If you have never ridden before, I would recommend a dirt bike to begin on. As said by Lepperfish, you can get used to the in the dirt, they have a easy/upright riding position and are easy to control at slow speeds. Also if you drop a dirt bike, it isn't going to damage it as much as a nice new road bike.
I did my NSW L's in 2002. I had never ridden before, around 6yrs driving cars. First bike was a ZZR250. Second bike was a ZXR750 L2. I rode the ZXR250 and CBR250RR.
The ZXR250 was much more responsive than the ZZR, very quick and braked well, and both are uncomfortable after an hour and a bit. The difference between the ZXR and the CBR is much of a muchness, ie. stuff all.
The guys that said the Kawasaki is just wider have hit the nail on the head. You won't have any dramas learning on either of the bikes. Just like when you bought your R33, you just have to use the throttle in proportion to your ability and experience. There are guys here that learned to drive in a GTSt.
Boj01 said that the sports bikes suck when doing the P's test. He is 100% spot on. Rent a CB250.
:) Enjoy bikes, they are awesome. I've never felt the same feeling of speed and fragility as I did on my bike. Then you can join the club of riders that insist on referring to cars as 'cages'. :(
Mark
mmm glad someone brought up bikes :(. Brings back memory's of riding every single weekend. I agree with some of the others, learn to ride up the bush or even in some's paddock. I learnt on my CR 80 and i crashed way to many times and suffered almost as many injuries and thats with just trees and the ground to hit. Hell, even spend 500 bucks on a piece of Shyt trail bike and thrash it till it dies. The skills u learn could safe your life.
o and id go the cbr250rr
once you get a bike every other car seems slow (hehe maybe not all)
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
