Hey guys,
Got my air con regassed 2 weeks ago after it was drained in Japan. Had it leak tested, etc and it was fine. Now the air con is warm and there's no gas in it. Took it back to the guy who now says the metal line from the firewall to the compressor is stuffed and leaking gas?
Wouldn't this have shown up on the leak test? How does a metal line leak anyway? Is he talking shit and if not does anyone have this line in non leaking order :)
cheers!
https://www.sau.com.au/forums/topic/66258-r32-ac-help/
normally hard to pick up leaks unless gas and dye has been put in system and then leaked out again, the uv dye showing the leak.
tho the leak should have been picked up if he says he tested it, normally the system is pressurized with nitrogen or lpg etc, and the leak can be heard.
it is very common for the aluminium lines to leak, they are quite thin and can crack and bend easy, especially if they rub against something
usually if u cannot find a replacement line, the leak (usually a small pinhole) is welded up, this will fix it.
https://www.sau.com.au/forums/topic/66258-r32-ac-help/#findComment-1235271
cheers dude, yeah it was pressure tested and dye tested... he said it seems its leaking around the valve closest to the firewall.
i'll let you in another thing and that is r32 would have originally been charged with r 12 refrigerant. The ga we use now is a smaller molecular structure than the old r 12 . So this means even if you get the leak fixed it will eventually still leak thru the rubber hoses. answer replace all hoses or keep spending good $ after bad ?
https://www.sau.com.au/forums/topic/66258-r32-ac-help/#findComment-1237202
It was recharged with R12. That's what the sticker he put on it says. I'll get it redone if its just seals,
When I did have it I noticed the smell of gas every now and then and condensation appearing on the top of the console near the vents. If that's the case, how would gas get into the vents themselves?
this blows! I was looking forward to air con again :)
https://www.sau.com.au/forums/topic/66258-r32-ac-help/#findComment-1237438
Well if he did that it is against the law it is good to replace with SP34E as link will explain,
http://www.solpower.com/sp34e/sp34emain.asp
If he put normal 134A in it dosent mix with the oil in the compressor from R12 or along those lines.
https://www.sau.com.au/forums/topic/66258-r32-ac-help/#findComment-1237789
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
