Opinions on injector upgrades needed!
-Engine rb30det VCT HEAD around 300-350rwkw
Just picked up the long motor from the engine builders and before slinging it back in I need to sort out my fuel delivery issues.
To get around the expensive side feed problem I have had a fuel rail built to suit the more popular top feed injectors but am struggling to find out what injectors will do the job cheaply. I have worked out that they will need to be around 550cc to flow enough for the power output but I'm having issues with compatabilty with the Apexi PFC. It likes high impedence Jap brands and the common Bosch 363(low impedence) apparently don't work to well with the PFC. I have heard RX7 S6 secondary injectors work OK but they are proving expensive and hard to get secondhand. Anyone have a proven setup that will suit this setup?
https://www.sau.com.au/forums/topic/66264-injector-gurus-wanted/
go to the SARD 700CC bolt in injectors - sell your rail.
The rail is costing me nothing and sard product is very expensive. My intake manifold doesn't know if the fuel is coming from a $50 injector or a $200 injector and I would rather spend my budget on upgrading my rods to race items and ceramic coating my forgies......but...... sards would be nice and easy if I had the bucks...
Anyone else have a proven solution?
Simple, use low impedance, top feed injectors and put a resistor in series with them to bring them up to high impedance. I am using the usual S5RX7T, which are rated at 550 cc's, but actually flow around 565 to 570 cc's at 36 psi base rail pressure and 625 cc's at 45 psi.:(
Aha , the Kid is in the house. As always, cheers for the input. My Tuner (ex apexi japan trained) tells me that he has had probs making low imp units work nicely with the PFC (specifically Bosch 363's which can be bought cheap/flow around 550cc and are a common performance upgrade). Within the PFC you can tell it what injector setup you have, what have you told it when you use those s5 rx7 units? are they primary or secondary units? shit it's frustrating not knowing....
ta
ta
I am not a rotary expert, but I think the S5RX7T had 4 X 550 cc injectors. I got mine off a well know rotary race engine builder a couple of years ago, we went though 8 to get 6 good ones.
I believe you would have problems with just low impedance injectors. but the resistors should fix that. As for settings, I didn't tell the Power FC anything, I just tuned the maps. The default injector lag is 0.528 milliseconds at 14volts.
I believe that Rochester make high impedance top feed injectors, so maybe try them. The Electromotive ECU (popular in US racing) runs peak and hold which likes low impedance, so they should be cheap and popular over there. With no import duty (free trade agreement, good on you Johnny) they are even more economical.
Hope that helps:cheers:
why are you cutting corners for a big power motor?
i'd be using the normal rail with nismo 700cc injectors and then you know 100% they will work without any problems at all as they are tried and proven.
im not even using an adj reg and ive got no problems
So, in spite of Sard injectors known for being hard to fit (not a drop in, even with collars!), hard to tune (non-standard injector lag) and as side feed injectors, generally a pain in the ass to remove and install (pintle caps off of the shelf are they?), you recommend them do you? They are the cheapest of the jap side feeds and it shows. If you *had* to go side feeds, the nismos or hks are a far better choice.
Rails cost nothing and theres a far greater range of top feeds. I don't blame the_tonkau for going this route.
Thanks for the imput guys! Spending big bucks doesn't always mean the best solution as many tuners of modded cars know all to well. Lets say I find a cheaper way around the touch your toes/bend over cost of expensive side feed injectors, I'm sure alot of the people on this forum would be able take advantage of this cheap solution. Isn't that the idea of this forum? to share idea's and solve problems economically?
Keep the idea's coming team!
Cheers
  • 3 weeks later...
Another idea is to get a company like AVO to high flow stock injectors also. Apparently you can get stock rb25 370cc jobs up to 500cc........
Yep, but they charge more than I can buy new 550cc Rochester injectors for:cheers:
Well guys, in the end I went down the route of reco S5 RX7 injectors (high impedence 550cc top feed) for $300 and had a mate from Mullins Engineering in Bayswater make me up a new fuel rail. Looks great and from the research completed, should work great. Next issue is trying to make the rb25det plenum fit under the bonnet (r33 S1 gtst) after the rb30det went in! wish me luck lads!
cheers
stevo
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
