hey guys for sale is my R32 1989 model 4 door.
only has 91000 on the clock
it has been a reliable car for the past 6 months but now its time to upgrade.
it is in pretty good condition for its age with a few small stone chips here and there as well as a couple of new dents to the front right fender (nothing major just got hit by a trolley while i was at work some time lat week, left little scratches)
ok the mods. it is pretty much a stock car with only an upgrade in exhaust to 2 1/4 inch size and 5 inch bodied 4 inch tip drift cannon style muffler.
it is a 5 speed Manual with the usuall power options (Power Steering, power windows, power mirrors) has central locking, Climate Control AC (was re-gassed 10 months ago) LSD and extractors
the interior is very clean except for a broken passenger air vent (they only cost about $50) and there is a Sony Xplod MP3 CD player (CDX-R3300S)]
has 6 months QLD rego and RWC so no hassels for new owner finding out it cant be registered.
its N/A so there is no hassels with insurance.
Very clean Well maintained car
first owner in australia Genuine reason for sale, need to sell soon
so any offers around 8000 ono will be accepted.
[/b]PRICE DROP NOW ONLY 6500[/b]
pm me or you can contact me on 0439794895
https://www.sau.com.au/forums/topic/66286-r32/
why don't you just tell everyone that it is NA to stop them asking over and over.
and you should change the original post where you say
split pump/front pipes
because this car is not turbo and therefore doesn't have a DUMP pipe, so I can only assume that you are refering to a set of extractors.
https://www.sau.com.au/forums/topic/66286-r32/#findComment-1244310
    • A bit of data is always good, beats the Facebook experts with their opinions I have Bosch 1480cc injectors, often called 1650cc (only when run at 4bar). I run mine at 3bar base so I don't thrash the fuel system. Up top, making 437kW with boost dropping, injector duty is at 69% on E80 (might have had some residual 98RON in there)
    • I have some downtime due to winter, and just wrapped up converting the car over to flex fuel. We don't get E85 at the pump over here in Canada, but I will be running Ignite E90 Race gas. I'll be mixing it with 99-100 RON pump gas and shoot for 50% ethanol content, up to possibly 85% content if there's any noticeable gains. Here's the question. Most I'll ever want to hit is ~600rwkW. I've currently running 1200cc injectors and want to keep them under 90% duty cycle. As per some online injector calculators, I should be good with 1200's well past 600rwkw on E85. As per other calculators, I'll need 1600-2000cc's. The variety is rather amusing.  With you Australians having E85 at the pump, what realistic duty cycles are you seeing in those kW ranges on E50 & E85 on your injectors? Thanks,
    • No issues here with my PRP gears in an OEM pump housing. I did confirm all housing clearances were to spec prior though. Cheers.
    • Thread is a bit old but figured id give my input anyway just incase. Have had lots of water problems in my R32 and was getting sick of wet tools in the boot and water filling up half my taillights. I ended up finding that whenever my car had been repainted they didn't reseal the taillights to the body of the car so water was just flowing straight into the boot, this is amplified by all the water around the bootlid being directed down to the taillights so would get pretty wet whenever I washed the car or it rained. You could probably use silicone to seal them to the body but I think from factory they use a roll of automotive grade butyl rubber. Hopefully this helps you if that ends up being how the water is getting in on your car!
    • Correct And whatever you do, don't use an oil pump gear, especially the one that starts with the same letter as Santa and the last letter ends with the same first letter as Lagoon. Get a proper oil pump, like a Nitto, Tomei, etc. and make sure you invest in a big fk off sump. Won't go into too much detail, but I am sure it caused my previous built motor to go bang.
