G'day guys
I am planning to buy cefiro in the future, but there are something bothering me.
I want to have better brakes and better grip.
At the moment I have aftermarket wheels off skyline with 5 stud. I really love the wheels and I would like to use them on my future cefiro.
Will the hub from s14 200 sx fit cefiro? or as s14 have 4 pot brake will the whole stub axle and hub unit of s14 200sx fit to cefiro strut and control arm?
Thanks guys
https://www.sau.com.au/forums/topic/66294-5-stud-wheel-pattern-on-cefiro/
Id you want to use the S14 or S15 hubs you will need to get the lower control arm (should still be attached - much easier this way). This bolts straight up to the Cefiro mounts. Cefiro shocks will bolt straight on also, as will the caliper (der, its on the hub). Simple!
JK
You can also use moog ball joint. And just buy the spindle and hubs and caliper and brakes.
i am trying to sell mine as I bought the ball joints and the hubs off a s14, but only ended up using 1 hub and still have both spindles, ball joints, and the calipers and rotors, and 1 hub.
If you want em make an offer
here is a site to check out.
http://www.pdm-racing.com/products/5boltco...conversion.html
if the stock ones are stock S13 brakes which im sure they were, then couldnt u just do the upgrade pack from g-13 garage?? its like 800 or something for R33 brakes
www.garage-13.com
Speak to Alex... hes a bit of a space cadet but hes alright :rofl:
www.garage-13.com
I emailed them 2 months ago about this, and a locker diff... Still haven't heard back. I'm sure their busy.. But not to hear anything back kinda annoyed me.
Can any one confirm the email address on the site is still correct?
I know that I can buy the adaptor for using r33 brakes but I want 5 stud as well as I want to use my old wheels (Volk TE-37 off my R33), I'd fallen in love with those wheels.
However I am not sure if the skyline hub will fit to the cefiro stub axle, so I need the information from you guys about this. If they fit it would be sweet.
I don't want to use the stud adaptor considering the safety.
yeah the hub from a skyline wont fit on the s13 spindle, you need to get new spindles, and I am not sure if the offset is going to be right if you try and bolt on skyline brake and spindles???
You got to go either S14, or buy upgrade hubs, which you can buy but very expensive, I had a look and decided not to as you only really temporarily fixing the problem.
As I said I have got all you need for s14 front except for 1 hub if you wanna buy, and I dont want much cash for them.
  • 3 weeks later...
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
