I have been tested once and warned twice by the EPA of my exhaust being too loud.
And to be honest I am sick of it's loudness too!
Can any prescribe a quick cheap fix?
I was looking at getting one of these silencer baffle plates which goes at the end of the muffler, are they known to actually quiten the exhaust sound down or is it just a wank?
https://www.sau.com.au/forums/topic/66352-exhaust-quiten-help-asap-plz/
Apexi ECV (Exhaust Control Value) no cheap tho around $200-$300 plus install.
You can adjust the volume of airflow through your exhaust in cabin (its like a butterfly)
do a search on it, (the are fitting just before the CAT)
but like i said not cheap.
these silencer baffle plates that your referring to will REDUCE the sound of your exhaust & ALSO performance.
if you intend to put on of those silence baffle plates on (don't rev/push your car because it isn't good for your car), you may as well get a STOCK exhaust system.
OR if you intend to use your car daily driver then get one of those silence baffle plates then TAKE it off when you goto track or whatever (i had one of these on my car NOT easy to TAKE off), it came with my apexi n1 exhaust and alot of aussie brand mufflers usually include them these days but are adjustable.
UP TO YOU MY FRIEND>
:rofl:
why don't you just get an exhaust shop to put in a couple of straight through mufflers? my system has 2 x 3in mufflers and it is legal - cost $150 per muffler and didn't hurt the exhaust flow.
one goes at the rear (where you normally see the cannon type mufflers) and the other under the car just in front of the L/H driveshaft.
