24,000km
$42,500 ono
250KW at the wheels @ 1.2Bar
Spent over $150,000
ENGINE:
froged arias pistons
eagle conrods
port and polished head
tomei cams
tomei cam gears
tomei valve springs
tomei head gasket
tomei valve guide
tomei rocker arm stoppers
HKS GTRS ball bearing (2540 equivilent) turbo
JIC turbo manifold
tomei dump pipe
HKS front pipe
HKS Silent High power cat back with hi-flow 3" cat
NISMO 740cc injectors
Spitfire coilpacks
HKS 700hp fuel pump
Sard fuel pressure regulaqtor
HKS oil cooler
Greddy intercooler kit
Cusco oil catch can
Exeedy hyper single clutch kit
Greddy air filter kit
Z32 airflow meter
ELECTRONICS:
Blitz ID digital boost controller
Blitz ID power meter
Apexi Power FC with hand controller
SUSPENSION/WHEELS/BRAKES:
Tein NA height damper adj. with camber tops front + rear
Cusco front strut brace
Cusco front + rear sway bars
Buddy Club 17" P1 Racing gunmetal grey with Toyo Proxes 225/45 (front) Bridgestone Potenza 245/40 (rear) tyres
Brembo cross drilled/slotted brake rotors
INTERIOR:
genuine JDM s15 airbag leather steering wheel with S emblem
genuine red Recaro SR5 seats
Greddy electronic boost guage A piller mounted
Pioneer MD deck with CD stacker
Boston Acustic Ralley splits
Infinity audio rears
Alpine Type R sub 12in boot mounted in custom enclosure
Hyphonics 5 channel amp
EXTERIOR:
C West front bar
Veilside rear bar
Factory side skirts
HID headlights
vented Carbon fiber bonnet
FACTORY ITEMS:
Sun roof
6 spd gearbox
LSD
NOTE:
NSW registered
Nissan service history
Recent Dyno tuned 250KW ATW
Will not seperate parts
Genuine enquires only
Email offers to [email protected]
Pictures will be posted soon on www.ezzy-style.com.au
https://www.sau.com.au/forums/topic/66358-fs-2001-blue-s15-spec-r-250kw-atw/
  • 3 weeks later...
the S15 is still for sale.
now a few reasons/issues/problems why it is still for sale.....
1. have had a few interested parties came by and inspected the car, all happy with it but just couldnt get the finance approved
2. his wife wants the car to go
3. its occupying some useable space
4. his wife still wants the car to go
5. its collecting unnecessary dust
6. his wife def. wants the car to go
7. he wants to keep the S15, but the wife wants the car to go
so after a lengthy phone call.... he has decided to drop the price to $37,000
pls call or drop us an email for more info/inspection.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
