Uhm.. I had a little accident in the car. :Oops:
I was driving on my merry way back to work after getting subway for lunch when i braked a little hardish for my drinks liking and it decided to spill everywhere! :rofl:
So I now have a swimming pool of coke and creaming soda on my drivers side floor and stickiness to my centre console and gearstick boot.
So can anyone recommend a carpet cleaner that can get rid of coke in the carpet and a bit on the seats?
https://www.sau.com.au/forums/topic/66373-carpet-cleaner/
:uhh:
I've parked it out the front of work with the windows down at the moment to try and dry it up. Is this a bad thing? I've also got paper towel down trying to soak it up... Hrm.. I might get andrew to go to Aussie Auto now and get something and I'll do it when I get home and leave it over night to work it's magic :rofl:
https://www.sau.com.au/forums/topic/66373-carpet-cleaner/#findComment-1236624
Use a damp sponge to wet and soak it up.
This will dilute the spill and remove as much residue as possible.
Don't use a hair dryer or heater or any artificial method of drying, this could damage your carpet.
The carpet in a lot of cars (not 100% sure for Skylines) can contain acrylic and artificial fibres which can melt really easy!
Open door and leave in the sun.
If still sticky
repeat.
https://www.sau.com.au/forums/topic/66373-carpet-cleaner/#findComment-1236676
Well I got andrew to grab some stuffs from Aussie Auto on the way down and he bought some Meguires stuff and some other thing cause it had a cool brush on the lid. :)
Luckily when I got home it was still wet so we just sprayed the stuff on it and cleaned it and left the windows down to dry it. While the car was at work, I placed some paper towel down to try and soak up some of it. It kinda worked :S
Thanks anyway guys.. now I just have to get the splash marks off my centre console, avcr, steering wheel, handbrake, gearstick, dask. :)
Never EVER taking that drink in my car again!
https://www.sau.com.au/forums/topic/66373-carpet-cleaner/#findComment-1237197
Can you sell me some of this... "AMWAY"... Bob?
I know where you can get it...unfortunately I cannot arrange until my return...sorry.
I swear by this stuff...and not any carpet cleaner will do (geez does that sound like a ****in cheezy sales pitch)...
I am sure you could look up Amway and thye would direct you to someone...
https://www.sau.com.au/forums/topic/66373-carpet-cleaner/#findComment-1237198
Yeah I had same prob in my last car with a mcdonalds drink....it's those stupid lids, if it tips over for any reason (esp. if it hits the floor) it's everywhere. Now I only take ones with screw on caps.
yea coke from maccas has done it to me before.....the centre console "drink holder" is to large for a large coke dammit....but yea its never posed a large problem always cleaned up ok
https://www.sau.com.au/forums/topic/66373-carpet-cleaner/#findComment-1237572
Strangely enough Spray and Wipe is great for home carpet stains and spills, I ahve also used it to remove stains from an older car..
I once left an Iced Coffe full on the back seat of my 180, a few days later, (I live in the Pilbar it was like 40 every day) I came ack to my car and the back seat had soaked up all the off milk, was one of the most disgusting smells that I have ever experienced. Took weeks to get the smell out, and basically once the smell was gone, a week later the car was smashed, poor car..
https://www.sau.com.au/forums/topic/66373-carpet-cleaner/#findComment-1237652
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
