i tried a search but didn't really get the answer i was looking for
basically i've got a clarion head deck 50x4 watts or whatever, alpine splits rated at 250 watts, i think 50 rms
the problem is when i turn the volume up a bit in these babies the tweeters start to crackle, and there doesn't seem to be too much bass, have i just wired it wrong?
i've been in other new cars that have a way better sound than this, that only have similar setup, like subaru's and xr6's
anyone know where i'm going wrong?
https://www.sau.com.au/forums/topic/66395-splits-crackling/
possible dodgy connections, or that you've blown them...had them long? ran them hard? (be honest :) )
All the Alpine speakers I have seen are way quiet without an amp, so you gotta crank them, but then they have issues. I have had 2 sets of alpines (not splits) and will never go alpine again...i was given some alpine splits which i run now, same problem, but they are loud enough to hear, unlike the other ones.
https://www.sau.com.au/forums/topic/66395-splits-crackling/#findComment-1237348
possible dodgy connections, or that you've blown them...had them long? ran them hard? (be honest :D )
i dunno it sort of sounds good down low, so i don't think i've blown them, i bought them at lifestyle and noticed that he was wearing a alpine shirt, (maybe gets dosh on the side to sell),
he showed me these other ones which looked slightly bigger, and a lot better bass, think they were jbl, mght get a couple of those jobies put them in the front, piss the sony crappers out of the back and put the alpine's in the back
https://www.sau.com.au/forums/topic/66395-splits-crackling/#findComment-1239721
  • 3 weeks later...
Splits dont have bass, thats what splits are for, so you have splits, just hign freq and then u have ya subs for the low freq.
the crackling you hear is whats called low level distortion, its because you are serverly underpowering them, and when you crank up the head deck to get it loud you are maxin the built in head decks amp and its only putting in a fraction of the power that the tweeters want, i hope that makes sense, its hard to describe.. but of course you could still have dodgy connections or they could be stuffed .. to check them out its best to remove the mid bass speaker and put your ear realy close to it and gently push the cone in and out with your fingers and listen for a scratching noise, it you can hear a slight scratching noise they are stuffed ..
Trust me it will be worth while to but an amp, even a cheap one. I dont know if you know much about car stereo's but splits are used only if you are running a sub, splits dont put any bass out at all that why you use a sub .. if you just have your head deck and you dont have an amp and sub you should be running 3ways, for example have 6inch 3ways in the doors and a pair of 6x9's in the parcel shelf .. you should pack the splits up and put them aside for when you decide to get an amp and subs and buy the 6inch 3ways and 6x9's, you will be happy with the sound i bet ..
https://www.sau.com.au/forums/topic/66395-splits-crackling/#findComment-1269242
Kill HSV, half the info you have been fed is incorrect I'm afraid.
Seeing as you're in Sydney, can you come down and see me sometime and I'll sort the whole front end out for you. There are many things that can cause (crackling) and I have not got time to write a thesis on it here I'm afraid. :thumbsup:
https://www.sau.com.au/forums/topic/66395-splits-crackling/#findComment-1269589
wow thanks man, didn't know that, suppose i'll be buying some 3 ways
https://www.sau.com.au/forums/topic/66395-splits-crackling/#findComment-1275150
Seeing as you're in Sydney, can you come down and see me sometime and I'll sort the whole front end out for you. There are many things that can cause (crackling) and I have not got time to write a thesis on it here I'm afraid. :rofl:
sounds like you do not no what your talking about he should buy a cheap amp and a set of 6x9 run the 6x9 of the amp and run the twetters of the head deck that way he can set the 6x9 through the amp and set the tweeters through the head deck like turn the bass down on the head deck and turn the bass up on the 6x9s
https://www.sau.com.au/forums/topic/66395-splits-crackling/#findComment-1278334
Tweeters from the head deck and 6x9's from the cheap amp.. lol He *could* do that.. but who wants a $200 p-plater sound system? Man I've heard this advice given out so many times and you end up with dumbass'es who don't know what sound well.. no front stage, no mid range and the whole thing underpowered.
If you're on a budget you're much better with (in order of budget allows) a decent H/U, front splits or coaxs from an amp and a sub from an amp.
Even no sub and decent fronts will kick the crap out of 6x9's in the back imo.
Right now I'm on a budget so I've got a pioneer 7650 (or thereabouts), a pioneer gmx414 amp 4 channel amp (discontinued and old but sounds nice) driving some focal polykevlar 2way 6.5" splits and the rear stock 6x9's turned way down for rear fill.
Noname $50 amp and $50 sub in a box (for now). If I have a large cashfall and my car is finally fine mechanically I'll be going for a 1.400 and a idmax 10" sub.
Fhrx knows what he's talkin bout, 10mins on the phone with him will tell you that much, or you could checkout his page on www.fhrxstudios.com .
Realistically though before you go buying new stuff try to fix the stuff you have already, and if you have the money talk to Fhrx he does some nice specials.
https://www.sau.com.au/forums/topic/66395-splits-crackling/#findComment-1278474
aaah... yeah. i'm with marty. and, no offense here Mick and others, but you've been ill-informed and are wrong. kill hsv, quite simply, it could be a whole plethora of problems causing you grief from wiring to dodgy components but let me assure you, it has nowt to do with "splits dont put any bass out at all that why you use a sub". "running 3ways, for example have 6inch 3ways in the doors and a pair of 6x9's in the parcel shelf" is not the right solution to your problem.... at all.
best of luck mate
d
https://www.sau.com.au/forums/topic/66395-splits-crackling/#findComment-1278741
sounds like you only got a $200 sound system lol
https://www.sau.com.au/forums/topic/66395-splits-crackling/#findComment-1279456
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
    • Well, moulded carpets should fit well if the buck they use is the right shape. The finish is then just a case of stiching the trim around the edges. Shuoldn't be too hard to get it right. Back in the day, replacement carpets were all "fitted", in that they were stitched together, with cuts and slices taken out to make them form the shapes. Many more opportunities to get it wrong, hence all the concern over good vendors and bad vendors.
    • A timely blog via AASA (keeping in mind they sell brake fluid of course...) https://www.msbgarage.com/blog/news-and-blogs/brake-fluid-what-should-i-use/
