splits crackling
KILL HSV
 Share
overboost for good sql you should have a strong front stage... it would be a bad idea to run the front off the deck and back amped... it just means when you turn it up you will get distortion through the fronts ...
id rather have amped front speakers and no back speakers
and yeah it would be intersting to see the thd stats on that pyle amp and the continuous output figures.....
I have Splits, 2 Subs, 4 amps etc etc etc .. but not everyone has that kind of money to spend on a system .. if he put some nice 3ways in the front and some coaxles or 6x9's in the rear he should be happy ..
hang on, so you're suggesting he buy new gear to replace the stuff that isn't working right???? seems illogical to me.
kill hsv, its just a matter of tracking down your problems with your tweets. i wouldn't be replacing a set of splits with "3-way's" and i'd rather poke myself in the eye than fit 6x9's.
you've got the right bits, just make them all talk to each other and they'll be just fine. you'll find that the separate component route (i.e. splits) will be a far better block upon which to build, should you want to upgrade and change things in the future.
and in regard to rear speakers, you'll find many "sq" systems run no rear speakers at all. pardon the cliche'd phrase from the audio world, but you don't go to a live gig and hear the performers from behind you. rear fill is best left to providing rear-seat passengers with music and multichannel surround systems imo. if you want to run rears, cross them over high (really high) so as to avoid pulling your soundstage backwards and try to fade them out as much as realistically possible.
cheers
d
overboost, I don't suppose you have the specs to that Pyle amp anywhere do you? I'd like to have a look over them if I may. :D
500 Watts X 4 Output
1000W x 2 Bridged Output (500 x 2 + 1000 x 1)
Dual Variable Hi/Lo Electronic Crossover Network
Dual Variable Bass Boost (0 - +18dB @ 60Hz)
Variable Input Level (Gain) Control
Remote Turn On/Off
Gold Plated RCA Inputs
High Level Molex Input
Power On LED Indicator
LED Protection Indicator
Blue LED Scanning Illumination
Remote Bass Boost
S/N Ratio: > 95dB
THD: < 0.04%
Thermal Protection
Overload Protection
Short Circuit Protection
Anti-thump Turn-on
Tri-Mode Configurable
Dimensions:10.87''X2.26''X17'' (WxHxL)
Just focusing on the power levels and THD, what is the power output at 12 volts, 13 volts and 14.4 and what resistance are these measured at?
Now I'm not having a shot at the amp at all or denying the claimed power, I'm simply interested. ;)
not bad ive seen amps that are tested and rated at a 0.10% THD (Total Harmonic Distortion) which gives ratings that are realy bogus .. THD is something to realy look out for.
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
