overboost for good sql you should have a strong front stage... it would be a bad idea to run the front off the deck and back amped... it just means when you turn it up you will get distortion through the fronts ...
id rather have amped front speakers and no back speakers
and yeah it would be intersting to see the thd stats on that pyle amp and the continuous output figures.....
I have Splits, 2 Subs, 4 amps etc etc etc .. but not everyone has that kind of money to spend on a system .. if he put some nice 3ways in the front and some coaxles or 6x9's in the rear he should be happy ..
hang on, so you're suggesting he buy new gear to replace the stuff that isn't working right???? seems illogical to me.
kill hsv, its just a matter of tracking down your problems with your tweets. i wouldn't be replacing a set of splits with "3-way's" and i'd rather poke myself in the eye than fit 6x9's.
you've got the right bits, just make them all talk to each other and they'll be just fine. you'll find that the separate component route (i.e. splits) will be a far better block upon which to build, should you want to upgrade and change things in the future.
and in regard to rear speakers, you'll find many "sq" systems run no rear speakers at all. pardon the cliche'd phrase from the audio world, but you don't go to a live gig and hear the performers from behind you. rear fill is best left to providing rear-seat passengers with music and multichannel surround systems imo. if you want to run rears, cross them over high (really high) so as to avoid pulling your soundstage backwards and try to fade them out as much as realistically possible.
cheers
d
overboost, I don't suppose you have the specs to that Pyle amp anywhere do you? I'd like to have a look over them if I may. :D
500 Watts X 4 Output
1000W x 2 Bridged Output (500 x 2 + 1000 x 1)
Dual Variable Hi/Lo Electronic Crossover Network
Dual Variable Bass Boost (0 - +18dB @ 60Hz)
Variable Input Level (Gain) Control
Remote Turn On/Off
Gold Plated RCA Inputs
High Level Molex Input
Power On LED Indicator
LED Protection Indicator
Blue LED Scanning Illumination
Remote Bass Boost
S/N Ratio: > 95dB
THD: < 0.04%
Thermal Protection
Overload Protection
Short Circuit Protection
Anti-thump Turn-on
Tri-Mode Configurable
Dimensions:10.87''X2.26''X17'' (WxHxL)
    • The GTT probably only has the same little bag of tools that the R32 had, which contained useless pliers, a spanner or two, a screwdriver thingo, and the handle and crank stuff for the jack.
    • ? 2s of searching finds this thread
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
