overboost for good sql you should have a strong front stage... it would be a bad idea to run the front off the deck and back amped... it just means when you turn it up you will get distortion through the fronts ...
id rather have amped front speakers and no back speakers
and yeah it would be intersting to see the thd stats on that pyle amp and the continuous output figures.....
I have Splits, 2 Subs, 4 amps etc etc etc .. but not everyone has that kind of money to spend on a system .. if he put some nice 3ways in the front and some coaxles or 6x9's in the rear he should be happy ..
hang on, so you're suggesting he buy new gear to replace the stuff that isn't working right???? seems illogical to me.
kill hsv, its just a matter of tracking down your problems with your tweets. i wouldn't be replacing a set of splits with "3-way's" and i'd rather poke myself in the eye than fit 6x9's.
you've got the right bits, just make them all talk to each other and they'll be just fine. you'll find that the separate component route (i.e. splits) will be a far better block upon which to build, should you want to upgrade and change things in the future.
and in regard to rear speakers, you'll find many "sq" systems run no rear speakers at all. pardon the cliche'd phrase from the audio world, but you don't go to a live gig and hear the performers from behind you. rear fill is best left to providing rear-seat passengers with music and multichannel surround systems imo. if you want to run rears, cross them over high (really high) so as to avoid pulling your soundstage backwards and try to fade them out as much as realistically possible.
cheers
d
overboost, I don't suppose you have the specs to that Pyle amp anywhere do you? I'd like to have a look over them if I may. :D
500 Watts X 4 Output
1000W x 2 Bridged Output (500 x 2 + 1000 x 1)
Dual Variable Hi/Lo Electronic Crossover Network
Dual Variable Bass Boost (0 - +18dB @ 60Hz)
Variable Input Level (Gain) Control
Remote Turn On/Off
Gold Plated RCA Inputs
High Level Molex Input
Power On LED Indicator
LED Protection Indicator
Blue LED Scanning Illumination
Remote Bass Boost
S/N Ratio: > 95dB
THD: < 0.04%
Thermal Protection
Overload Protection
Short Circuit Protection
Anti-thump Turn-on
Tri-Mode Configurable
Dimensions:10.87''X2.26''X17'' (WxHxL)
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
    • Well, moulded carpets should fit well if the buck they use is the right shape. The finish is then just a case of stiching the trim around the edges. Shuoldn't be too hard to get it right. Back in the day, replacement carpets were all "fitted", in that they were stitched together, with cuts and slices taken out to make them form the shapes. Many more opportunities to get it wrong, hence all the concern over good vendors and bad vendors.
    • A timely blog via AASA (keeping in mind they sell brake fluid of course...) https://www.msbgarage.com/blog/news-and-blogs/brake-fluid-what-should-i-use/
