  • Replies 66
My Link was bout $1100 without hand controller. Its a plug in but you gotta put link gear in factory ecu case. (Stealth) :P I friend has one in his STI and it runs perfectly. But as I said to you b4 mine hasnt been tuned yet so I cant really comment.
I have a LINK ecu in my 32 gtst.
I've had no problems what-so-ever apart from mechanics 'claiming' they can tune it, when they know fcuk all and screwed my car completely.
So be weary.
The two workshops that have tuned my car with success is Amberley Autos and AVO.
I have a severe problem at the moment with it though, as i am building another 32 gtst and have put the ecu into my new car, and i am MISSING the LINK map sensor !!! :D
Its weird, the r32 GTR LINK ecu, will run on the factory nissan map sensor, but the r32 gtst requires a LINK map sensor.
AVO have no more map sensors, and they dont know when they will be getting anymore... so this is stressing me out big time.
The only down side, is that the handcontroller has limited read out information i.e. only 1 line screen.
Ive searched and found bugger all threads on link engine management
Yes, there is a reason for that
but have been told they are the shiznit (no afm needed)
Brings me back to comment one.
If you aint seen many posts about something. Its hardly good.
If they were soo good everyone would be using them (such as a PowerFC)
Get a PFC and do yourself a favour
Ok, if your going to make a bold statement like that, you need to suggest/list some factual information here.
You are like 90% of the other posts on here that just go with 'the flow'
"Everyone Else Is Doing It, So It MUST Be Good !"
And thats the biggest crock of sh1t, and i hate reading peoples posts who have no actual idea what they are talking about, they just post what other people do.
List me some factual information for and against LinkECUs.
Sorry a was referring to your comment about the hand controller. Wasn't sure if you knew about the PClink stuff.
At the same time I guess a laptop in the car all the time is hardly convenient.
Adam
hehe, yeah i was merely comparing the handcontroller to a Wolf3D handcontroller or a PFC handcontroller which give you a range of information on the one screen.
Link have just brought out a few new products including a new ECU.
I know a lot of people using it as well as a few people who work for Link.
Like any ECU it's all about the tuner.
I have had bad luck with previous LINK computers and bad tuners.. and good luck with PowerFC and it working from just being plugged in.
If you have a good tuner that likes LINK, then it will work fine. Might be worth trying out LINKs new products.
Link is a "average" ECU.
For its price it is good - but compared to other ECU's its .... crap.
I had a link in my WRX ad it was good for what it cost me.
In regard to fuel point and ignition points for tunablity its crap compared to Motec, Autronics and even Apexi. It also lacks fuel correction for air temp, full throttle, closed throttle etc,,,
Link is crap - dont awaste your time or money - keep saving for a better ecu.
Check out the ECU Matrix here at Perth WRX - shows you a great comparison between the ecu's
http://web3.bekkers.com.au/~pwrx/phpBB2/vi...opic.php?t=6121
Daniel
yes, im more interested in fact as well
the more i look into them, the better they sound, im just wondering why more people arent using them
The thing with the link - and i really noticed it compared to my mates wrx with a motec m800 is drivability really is worlds apart.
Because the motec has so many load points the tuning ability is miles ahead.
Smoother driving, etc all very noticable. But the way you could really tell is in first gear my mate can take his 98 wrx upto about 80/85km (has a holinger dogbox) - and then take his foot straight off the peddle - and the car would smoothly decellaratedown in revs and speed with suck utter smoothness - i was amazing. Take my link ecu wrx up to 70 and take foot of in first and it would roughly come down and hive you that inital jerk ...
Miles apart.
Miles apart.
This is something i notice straight away, and it really tells the story as to whether a car has been tuned properly for driveability.
i NEVER had this issue with my LINK when it was tuned properly.
One thing that rings true though is that my car chews through fuel, and runs extremely rich.
But thats fine by me, last thing i want is the thing running lean... i cant expect a car with 300+rwhp to be decent on fuel. :cheers:
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
